#include "MQ135.h"
#include <SoftwareSerial.h>
#define DEBUG true
SoftwareSerial esp8266(0,1); // This makes pin 9 of Arduino as RX pin and pin 10 of Arduino as the TX pin
const int sensorPin= A0;
int air_quality;
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11, 5, 4, 3, 2);
pinMode(8, OUTPUT);
lcd.begin(16,2);
lcd.setCursor (0,0);
lcd.print ("AIR POLLUTION MONITORING SYSTEM ");
lcd.setCursor (0,1);
delay(5000);
pinMode(sensorPin, INPUT); //Gas sensor will be an input to the arduino
lcd.clear();
MQ135 gasSensor = MQ135(A0);
float air_quality = gasSensor.getPPM();
if(esp8266.available()) // check if the esp is sending a message
if(esp8266.find((char*)"+IPD,"))
int connectionId = ((esp8266.read())-48); /* We are subtracting 48 from the output because the read() function returns the ASCII decimal value and the first decimal number which is 0 starts at 48*/
String webpage = "<h1>IOT Air Pollution Monitoring System</h1>";
webpage += "<p><h2>";
webpage+= " Air Quality is ";
webpage+= air_quality;
webpage+=" PPM";
webpage += "<p>";
if (air_quality<=1000)
webpage+= "Fresh Air";
else if(air_quality<=2000 && air_quality>=1000)
webpage+= "Poor Air";
else if (air_quality>=2000 )
webpage+= "Danger! Move to Fresh Air";
webpage += "</h2></p></body>";
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend +=webpage.length();
cipSend +="\r\n";
sendData(cipSend,1000,DEBUG);
sendData(webpage,1000,DEBUG);
cipSend += ",";
cipSend +="\r\n";
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId; // append connection id
closeCommand+="\r\n";
sendData(closeCommand,3000,DEBUG);
lcd.setCursor (0, 0);
lcd.print ("Air Quality is ");
lcd.print (air_quality);
lcd.print (" PPM ");
lcd.print("Fresh Air");
digitalWrite(8, LOW);
else if( air_quality>=1000 && air_quality<=2000 )
lcd.print("Poor Air, Open Windows");
digitalWrite(8, HIGH );
lcd.print("Danger! Move to Fresh Air");
digitalWrite(8, HIGH); // turn the LED on
lcd.scrollDisplayLeft();
String sendData(String command, const int timeout, boolean debug)
String response = "";
esp8266.print(command); // send the read character to the esp8266
long int time = millis();
while( (time+timeout) > millis())
while(esp8266.available())
// The esp has data so display its output to the serial window
char c = esp8266.read(); // read the next character.
response+=c;
if(debug)
Serial.print(response);
return response;
here is the code and circuit diagram is also attached .my project show result on LCD but not on web browser .
Pins 0 & 1 should not be used for software serial because these are the hardware serial pins.
Use other pins, then you can use the serial console for debug statements like Serial.println( webpage ) to see how far through the logic your code is progressing.
#include "MQ135.h"
#define DEBUG true
SoftwareSerial esp8266(9,10); // This makes pin 9 of Arduino as RX pin and pin 10 of Arduino as the TX pin
const int sensorPin= 0;
int air_quality;
pinMode(8, OUTPUT);
lcd.begin(16,2);
lcd.print ("circuitdigest ");
lcd.print ("Sensor Warming ");
esp8266.begin(115200); // your esp's baud rate might be different
sendData("AT+RST\r\n",2000,DEBUG); // reset module
sendData("AT+CWMODE=2\r\n",1000,DEBUG); // configure as access point
sendData("AT+CIFSR\r\n",1000,DEBUG); // get ip address
sendData("AT+CIPMUair_quality=1\r\n",1000,DEBUG); // configure for multiple connections
sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // turn on server on port 80
lcd.clear();
if(esp8266.find("+IPD,"))
int connectionId = esp8266.read()-48; /* We are subtracting 48 from the output because the read() function returns the ASCII decimal value and the first decimal number which is 0 starts at 48*/
webpage+=" PPM";
webpage += "<p>";
cipSend += ",";
cipSend +="\r\n";
cipSend += ",";
cipSend +="\r\n";
response+=c;
if(debug)
return response;
firstly i have write this code(circuit digest's code) but its not working so i made changes which i have posted and still its not working
#include "MQ135.h"
#define DEBUG true
int air_quality;
pinMode(8, OUTPUT);
lcd.begin(16,2);
lcd.clear();
webpage+=" PPM";
webpage += "<p>";
cipSend += ",";
cipSend +="\r\n";
cipSend += ",";
cipSend +="\r\n";
response+=c;
if(debug)
return response;
my ESP8266 (WI-FI MODULE) is not working with this code.
You will be very lucky if software serial will work at 115200 baud. My experience is that software serial will not work, reliably, at more than 38400 baud. Do you know for sure what the ESP baud rate set to?
