ESP8266 Making POST to Server Not Working
I have a esp8266 connected to arduino to do post to an apache2 server, but it seems that in arduino it does not get return from the server, the apache log never registers anything and when it registers it is a 408 error (quite rare to happen! PING to the IP of the ESP and it responds), as I am doing the tests on my network, I looked at the devices connected in the router and the IP of esp8266 does not appear.
On the linux server that has apache, I ran the iptraf program to see what happens and it appeared in the Flags column:
S-A- (server) and --A- (ESP) .
I've tested everything and so I come here to ask for help for you.
This is the complete code:
#include <SoftwareSerial.h>
#include <avr/pgmspace.h>
// RX, TX wifi ESP-01
SoftwareSerial esp(2, 3);
#define CF(x) ((const __FlashStringHelper*)x)
const char ssid[] PROGMEM = "andre";
const char password[] PROGMEM = "xxxxxx";
boolean tcpConnect = false;
  esp.begin(19200);
  esp.println("AT+CIOBAUD=19200");
  esp.print("\r\n");
  resetEsp();
  connectEsp();
void resetEsp() {
  boolean go = false;
  int contErrorReset = 0;
  Serial.println(F("Reiniciando ESP..."));
  esp.println("AT+RST");
  esp.print("\r\n");
void connectEsp() {
  int contErrorConnection = 0;
  Serial.println(F("Conectando ESP..."));
  do {
    esp.flush();
    esp.print("AT+CWJAP=\"");
    esp.print(CF(ssid));
    esp.print("\",\"");
    esp.print(CF(password));
    esp.print("\"");
    esp.print("\r\n");
    delay(2000);
    if (esp.readString().indexOf("OK")) {
    } else if (checkConection() == true) {
      // se não conecta na rede, incrementa
      contErrorConnection++;
  } while (contErrorConnection < 30);
  if (contErrorConnection == 30) {
    // reset
    asm volatile("jmp 0");
boolean checkConection() {
  esp.print("AT+CIPSTATUS");
  esp.print("\r\n");
  delay(2000);
    return true;
  return false;
  requestPost();
  delay(20000);
void requestPost() {
  // verifica conexao
    Serial.println(F("CONECTADO..."));
    Serial.println(F("NAO CONECTADO..."));
    delay(300);
  checkIP();
  //  esp.flush();
  // conexão tcp
  esp.print("AT+CIPSTART=\"TCP\",\"192.168.1.7\",80");
  esp.print("\r\n");
  int contErrorTCP = 0;
  do {
    if( esp.readString().indexOf("OK")) {
      Serial.println("TCP connection ready");
      tcpConnect = true;
      Serial.println("TCP connection not ready...");
      contErrorTCP++;
    if(contErrorTCP==5) {
      Serial.println("Reiniciando");
  }while(tcpConnect==false);
  delay(10000);
  esp.print("AT+CIPMUX=0");
  esp.print("\r\n");
  Serial.println(freeRam());
  String sendVal = "valpost=123";
  String postRequest = "";
  postRequest += "POST /climatempo/sensor_test.php HTTP/1.1\r\n";
  postRequest += "Host: 192.168.1.7\r\n";
  postRequest += "Accept: */*\r\n";
  postRequest += "Content-Length: " + String(sendVal.length()) + "\r\n";
  postRequest += "Content-Type: application/x-www-form-urlencoded\r\n";
  postRequest += "Cache-Control: no-cache\r\n";
  postRequest += "\r\n"+sendVal;
  // quantidade de caracteres na requisição
  String cmd = "AT+CIPSEND=";
  Serial.println("CARACTERES REQUEST: "+cmd);
  esp.println(cmd);
  esp.println(postRequest.length());
  esp.print("\r\n");
  delay(10000);
  Serial.println(esp.readString());
  if (esp.readString().indexOf(">")) {
    Serial.println(postRequest);
    esp.print(postRequest);
    esp.print("\r\n");
    if( esp.readString().indexOf("SEND OK")) {
      Serial.println(F("Packet sent"));
      while (esp.available()) {
        Serial.println(F("RESULT:"));
        String tmpResp = esp.readString();
        Serial.println(tmpResp);
  Serial.println(F("Vai encerrar"));
  delay(2000);
  // encerra conexão
  esp.print("AT+CIPCLOSE");
  esp.print("\r\n");
void checkIP() {
  do {
    esp.print("AT+CIFSR");
    esp.print("\r\n");
    Serial.print(esp.readString());
    Serial.println(F("VERIFICANDO IP..."));
  } while(!esp.readString().indexOf("OK"));
int freeRam () {
  Serial.print("Free SRAM in bytes: ");
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
Have you tried using a USB-to-TTL converter with Arduino IDE's Serial Monitor to talk to the ESP module to make sure that you are able to manually do what you want the Arduino to do programmatically?
ieee488:
No, I used it directly with the Arduino.
What I'm doing I've done once, so I'm wondering everything that's happening in the ESP and the server.
I'm using ESP with an adapter, I'll see if it uses resistors and see if the result turns out to be different, but I'm also in doubt if I'm not doing some wrong command.
I'm using this type of adapter:
http://www.dx.com/pt/p/esp8266-serial-wi-fi-wireless-esp-01-adapter-module-3-3v-5v-compatible-for-arduino-403053?tc=BRL&gclid=CjwKEAjw1PPJBRDq9dGHivbXmhcSJAATZd_BdbzbkMGUt8sMoxMueFfO4U2LFAfWGDQkwDgob1bDzxoCprjw_wcB#.WT1TO2vyvVM
I found the problem, it is the validation of what is returned from the ESP.
I was checking the ESP return with the command esp.readString().indexOf("OK"), I switched to esp.find("OK") and it worked, however, when compiling the code it deprecated alert, someone knows If you have a better way to check the ESP return?
