I am making an IoT weighing scale with a load cell connected to an Arduino. The Arduino then sends data to an ESP8266 connected by serial which would subsequently update my database on Google's Firebase. However, my ESP8266 throws an exception when it starts. Half of the time it works perfectly fine. The other half, the following is thrown when I connect my cable to it. This error is repeatedly thrown so I think it might be an error inside void loop() but I can't seem to figure out what exactly is the problem. Also, my cables are not the best quality but I am not sure if that affects anything.
Note that the error message was cut short.
Exception (0):
epc1=0x4025803e epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000000a depc=0x00000000
>>>stack>>>
ctx: sys
sp: 3fffe0c0 end: 3fffffb0 offset: 01a0
3fffe260: 00000000 00000000 00000000 00000000
3fffe270: 00000000 00000000 00000000 40104b72
3fffe280: 40104b54 3fffc100 0000001a 00000000
3fffe290: 00000000 4025803e 00000000 00000000
3fffe2a0: 400005e1 00000000 00000000 00000000
3fffe2b0: 4025803e 00000033 00000010 00000000
3fffe2c0: 4025803e 40266fd0 00000000 00000001
3fffe2d0: fbf8ffff 04000002 3feffe00 00000100
3fffe2e0: 0000001a 00000018 04000102 40104b54
The following is my code on the ESP8266. I apologize for any bad programming habits. I am a beginner. Feel free to improve my code as well.
#include <ESP8266WiFi.h>
#include <FirebaseESP8266.h>
//Hidden for security
#define WIFINAME
#define WIFIPASSWORD
#define BAUTRATE 9600
#define FIREBASE_HOST
#define FIREBASE_COMMAND_ADDRESS
#define FIREBASE_AUTH
WiFiClientSecure client;
FirebaseData firebaseData;
unsigned long previousTime;
String firebaseWriteAddress;
String firebaseReadAddress;
String weight; // Stored in a string to accomodate the "loading" text
bool maxWRead;
bool minWRead;
bool displayPrefRead;
bool instructedToConnectWifi;
void readWeights(){
// function to read the min and max weights, then send to Arduino
if (!maxWRead){
String maxWAddress = firebaseReadAddress + "/Product/MaxW";
if (Firebase.get(firebaseData,maxWAddress)){
if (firebaseData.dataType() == "string"){
String maxWMessage = "max:"+ firebaseData.stringData();
Serial.println(maxWMessage);
maxWRead = true;
if (!minWRead){
String minWAddress = firebaseReadAddress + "/Product/MinW";
if (Firebase.get(firebaseData,minWAddress)){
String minWMessage = "min:"+ firebaseData.stringData();
Serial.println(minWMessage);
minWRead = true;
void readDisplayPref(){
String displayAddress = firebaseReadAddress + "/Display";
if (Firebase.get(firebaseData,displayAddress)){
String displayMessage = "dsp:"+ firebaseData.stringData();
Serial.println(displayMessage);
displayPrefRead = true;
void sendFireBase(){
// function to send data to Firebase Real-time Database
Firebase.setString(firebaseData, firebaseWriteAddress,weight);
void readFireBase(){
Firebase.begin(FIREBASE_HOST,FIREBASE_AUTH);
if(Firebase.get(firebaseData, FIREBASE_COMMAND_ADDRESS)){
String data = firebaseData.stringData();
String command = data.substring(0,4);
if (command == "read"){
firebaseReadAddress = "/UserData/" + data.substring(4);
readWeights();
firebaseWriteAddress = "/UserData/" + data.substring(4)
+ "/Weight";
void connectWifi(){
WiFi.begin(WIFINAME, WIFIPASSWORD);
byte wifiCounter = 0;
// Allow some buffer time to connect to WiFi
delay(100);
wifiCounter ++;
if (wifiCounter > 50){
// tries for 5 sec.
if (WiFi.status() == WL_CONNECTED){
Serial.print("WiFi Connected!\n");
instructedToConnectWifi = true;
else {
Serial.print("Can't Connect. Trying Again\n");
connectWifi();
void readArd(){
// function to read Serial inputs from arduino
String message = Serial.readStringUntil('\n');
if (message == "ConnectWifi"){
connectWifi();
else{
weight = message;
// stores weight without the percentage sign. Only stores if its within 0-100
sendFireBase();
Serial.begin(BAUTRATE);
previousTime = millis();
maxWRead = false;
minWRead = false;
displayPrefRead = false;
instructedToConnectWifi = false;
if (Serial.available()){
readArd();
if (instructedToConnectWifi){
// if wifi disconnects halfway, auto connect back
if (WiFi.status() != WL_CONNECTED){
connectWifi();
unsigned long currentTime = millis();
if (currentTime - previousTime >2000){
// cycles every 2 sec to prevent spam
// TODO: fix overflow problem (49 days) if it becomes product
if (!minWRead || !maxWRead){
// stop once max and min has been read
readFireBase();
previousTime = currentTime;
else {
readDisplayPref();
