ESP8266 SMTP Email Interrupt IRQ ISR
Dear Arduino friends,
I have bought an ESP12E Board by NodeMCU to realise my favorite project: I want to recieve an Email, when my mailbox is opened, so I don't need to check it every day.
I am able to send a simple Email with SMTP2Go to my mail account. Now I want to initialize this process, when the Board recieves an interrupt on pin 4. I checked and it seems that this is the correct pin.
I attached my attempt to integrate the sending-process as an Interrupt-Service-Routine. But it seems that the "attachtInterrupt" function doesn't accept byte-functions. In line 17 i get the error:
"invalid conversion from 'byte ()() {aka unsigned char ()()}' to 'void (*)()' [-fpermissive]".
I tried to convert the byte functions into void, but it just got worse. Since i'm not a programming expert I hope that someone has an idea, how to integrate the whole process into an ISR, in order to set the board to a low-power mode in the next step.
Thank's for your help!
#include <ESP8266WiFi.h>  // the ESP8266WiFi.h  lib
const char* SSID = "*******";
const char* PASS = "*********";
char server[] = "mail.smtpcorp.com";
ADC_MODE(ADC_VCC);
WiFiClient client;
  pinMode(4, INPUT);
 attachInterrupt(digitalPinToInterrupt(4), sendEmail, HIGH);
byte sendEmail(){
  delay(10);
  Serial.println("");
  Serial.println("");
  Serial.print("Connecting To ");
  Serial.println(SSID);
  WiFi.begin(SSID, PASS);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi Connected");
  Serial.print("IP address: ");
  byte ret = sendEmail();
  byte thisByte = 0;
  byte respCode;
  if (client.connect(server, 2525) == 1) {
    Serial.println(F("connected"));
    Serial.println(F("connection failed"));
    return 0;
  if (!eRcv()) return 0;
  Serial.println(F("Sending EHLO"));
  client.println("EHLO www.example.com");
  Serial.println(F("Sending auth login"));
  client.println("auth login");
  Serial.println(F("Sending User"));
  // Change to your base64, ASCII encoded user
  client.println("*************"); // SMTP UserID
  Serial.println(F("Sending Password"));
  // change to your base64, ASCII encoded password
  client.println("***********");//  SMTP Passw
    Serial.println(F("Sending From"));   // change to your email address (sender)
   client.println(F("MAIL From: esp@gmail.com"));// not important
   if (!eRcv()) return 0;   // change to recipient address
    Serial.println(F("Sending To"));
    client.println(F("RCPT To: **********"));
    Serial.println(F("Sending DATA"));
    client.println(F("DATA"));
    Serial.println(F("Sending email"));   // change to recipient address
   client.println(F("To: *************"));   // change to your address
   client.println(F("From: ***********"));
 client.println(F("Subject: Emails from ESp8266\r\n"));
    client.print(F("Power is: "));
    client.print(ESP.getVcc());
    client.println(F("mV"));
    client.print(F("Device Chip ID: "));
    client.println(ESP.getChipId());
    Serial.print(F("Voltage is: "));
    Serial.print(ESP.getVcc());
    client.println(F("."));
    Serial.println(F("Sending QUIT"));
    client.println(F("QUIT"));
    client.stop();
    Serial.println(F("disconnected"));
    return 1;
  byte eRcv()
    byte respCode;
    byte thisByte;
    int loopCount = 0;
    while (!client.available())
      delay(1);
      loopCount++;     // if nothing received for 10 seconds, timeout
      if (loopCount > 10000) {
      client.stop();
      Serial.println(F("\r\nTimeout"));
      return 0;
  respCode = client.peek();
  while (client.available())
    thisByte = client.read();
    Serial.write(thisByte);
  if (respCode >= '4')
    //  efail();
    return 0;
  return 1;
  while(1){
you can't send e-mail or doing anything complex in the interrupt. set a global volatile boolean variable in interrupt to true and in loop check that variable. if it says 'true' then call the sendEmail function
Ok, thanks for your quick reply! That's a good idea, I'm wondering if I can set the controller to low power mode, so it doesn't use so much power. It should be battery-powered.
I am no expert for low power. I know that esp8266 has some automatic power saving and there is a ESP.deepSleep() function arduino core.
