ESP8266 WiFi reconnection after sleep
Hello,
I am trying to develop a program where my ESP9266 goes to sleep for 10 seconds and every time it wakes up it re-establishes WiFi connection. The first time the connection is done successfully, but after waking up from sleep it doesn't connect again. Any idea why? This is the code:
#include <ESP8266WiFi.h>
const int wakeUpInterval = 10 * 1000000; // Wake up interval in microseconds (10 seconds)
const char* ssid = "xxx";
const char* password = "xxx";
  while (!Serial);
  Serial.print("Connecting to WiFi...");
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("Connected to WiFi!");
  // Enter deep sleep
  Serial.print("Going to sleep...");
  delay(1000); // Give some time for Serial output to complete
  WiFi.disconnect(); // Disconnect from Wi-Fi before entering deep sleep
  delay(100); // Give some time for disconnection
  // Configure deep sleep
  ESP.deepSleep(wakeUpInterval, WAKE_RF_DISABLED);
  // Do nothing in the loop function
When it sleeps , it re awakens where it left off - at the end of your setup .
You need something in loop to check and reconnect .
If you lost connection whilst it was running you wouldn’t regain the connection either, this can happen anytime .
There maybe a setting whereby an 8266. Will reboot on wake-up, but it’s not a great route.
  • I’ve no idea google might know ?
setup();
@mribeira
Connect D0-pin with RST-pin (Fig-1) and then try the following tested sketch (your one with some moderation):
(Quote: The RST pin of the ESP8266 is always HIGH while the ESP8266 is running. However, when the RST pin receives a LOW signal, it restarts the microcontroller.
If you set a deep sleep timer with the ESP8266, once the timer ends, GPIO 16/D0 sends a LOW signal. That means that GPIO 16/D0, when connected to the RST pin, can wake up the ESP8266 after a set period of time.)
Figure-1:
const int wakeUpInterval = 5 * 1000000ul; // Wake up interval in microseconds (10 seconds)
const char* ssid = "SiamWifiNew"; //enter ID of your Router
const char* password = "siam1234"; //enter password for your Router
  while (!Serial);
  connectWiFi();
  // Enter deep sleep
  Serial.println("Going to sleep...");
  Serial.println("ESP8266 has waked up.");
  connectWiFi();
void connectWiFi()
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
