Esp8266 with dht22 cant make it work
hello everyone i having a little problem displying temp on web server can anyone help me please
im using this code from adafruit but i dont know anything about coding i just did copy and paste changing only ssid and password :slight
there is a line saying // if you add this subdirectory to your webserver call, you get text below :slight_smile:
how to add that part? because the only text show in a browser is this "Hello from the weather esp8266, read from /temp or /humidity"
i read everything on diferent website but cant understand anything
thank you for your time
Have a great day
/* DHTServer - ESP8266 Webserver with a DHT sensor as an input
   Based on ESP8266Webserver, DHTexample, and BlinkWithoutDelay (thank you)
   Version 1.0  5/3/2014  Version 1.0   Mike Barela for Adafruit Industries
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <DHT.h>
#define DHTTYPE DHT22
#define DHTPIN  2
const char* ssid     = "YourRouterID";
const char* password = "YourRouterPassword";
ESP8266WebServer server(80);
// Initialize DHT sensor
// NOTE: For working with a faster than ATmega328p 16 MHz Arduino chip, like an ESP8266,
// you need to increase the threshold for cycle counts considered a 1 or 0.
// You can do this by passing a 3rd parameter for this threshold.  It's a bit
// of fiddling to find the right value, but in general the faster the CPU the
// higher the value.  The default for a 16mhz AVR is a value of 6.  For an
// Arduino Due that runs at 84mhz a value of 30 works.
// This is for the ESP8266 processor on ESP-01
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
float humidity, temp_f;  // Values read from sensor
String webString="";     // String to display
// Generally, you should use "unsigned long" for variables that hold time
unsigned long previousMillis = 0;        // will store last temp was read
const long interval = 2000;              // interval at which to read sensor
void handle_root() {
  server.send(200, "text/plain", "Hello from the weather esp8266, read from /temp or /humidity");
  delay(100);
void setup(void)
  // You can open the Arduino IDE Serial Monitor window to see what the code is doing
  Serial.begin(115200);  // Serial connection from ESP-01 via 3.3v console cable
  dht.begin();           // initialize temperature sensor
  // Connect to WiFi network
  WiFi.begin(ssid, password);
  Serial.print("\n\r \n\rWorking to connect");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.println("DHT Weather Reading Server");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.on("/", handle_root);
  server.on("/temp", [](){  // if you add this subdirectory to your webserver call, you get text below :)
    gettemperature();       // read sensor
    webString="Temperature: "+String((int)temp_f)+" F";   // Arduino has a hard time with float to string
    server.send(200, "text/plain", webString);            // send to someones browser when asked
  server.on("/humidity", [](){  // if you add this subdirectory to your webserver call, you get text below :)
    webString="Humidity: "+String((int)humidity)+"%";
  server.begin();
  Serial.println("HTTP server started");
void loop(void)
  server.handleClient();
void gettemperature() {
  // Wait at least 2 seconds seconds between measurements.
  // if the difference between the current time and last time you read
  // the sensor is bigger than the interval you set, read the sensor
  // Works better than delay for things happening elsewhere also
  if(currentMillis - previousMillis >= interval) {
    // save the last time you read the sensor
    // Reading temperature for humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
    humidity = dht.readHumidity();          // Read humidity (percent)
    temp_f = dht.readTemperature(true);     // Read temperature as Fahrenheit
    // Check if any reads failed and exit early (to try again).
    if (isnan(humidity) || isnan(temp_f)) {
      Serial.println("Failed to read from DHT sensor!");
      return;
I've had this problem as well, but I still haven't found a solution.
What happens when you go to http://X.X.X.X/temp ?
if i find the solution ill let you know
show this ==> "Hello from the weather esp8266, read from /temp or /humidity"
I fixed it using the Auto Format under tools and this command AT+UART_DEF=9600,8,1,0,0. I don't know if that helps but, I recommend watching this video.
Please show a screen shot, including the address bar of the browser.
here there is no more info just the text
This is not the correct web address !
http://192.168.0.18
You need to put /temp on the end !!!
http://192.168.0.18/temp
Thank you
i just did that check this screenshot
i forgot to mention
in the serial monitor now i have a problem
21:07:43.461 -> Working to connect.............roomtemp
21:07:50.678 -> DHT Weather Reading Server
21:07:50.678 -> Connected to Lod-2.4
21:07:50.678 -> IP address: 192.168.0.18
21:07:50.678 -> HTTP server started
21:08:21.526 -> Failed to read from DHT sensor!
Post a schematic of how everything is connected.
What sensor are you using?
thank you for your time.
im using this picture
im using this HiLetgo ESP8266 NodeMCU
HiLetgo DHT22/AM2302
What happens if you refresh the page?
