I am trying to send AT commands to a ESP 8266. But I am getting no responds. I am using the TX and RX pins of the Arduino uno. I am not even getting a “ready”.
I connect: vcc to 3.3v, GND to ground, TX to RX, RX to TX and CH_PD to 3.3v. I have also tried to connect RST to ground. But that also did not work. I also don’t now witch baud rate I should use, I have tried 115200, 57600 and 9600.
Making sure I got the issue correct, you connected a 5V Arduino product, without level shifters, to a 3.3V ESP8266 and, you think the ESP8266 is not doing the thing. That could be a problem.
Idahowalker:
This is not the problem. esp8266 can tolerate 5 V serial communication
You don't say which ESP8266 module, but I'm assuming ESP-01.
I'd recommend pulling the ESP-01 RST, GPIO0, and GPIO2 pins high to ensure it comes up in the operational mode. Preferably they should be tied to 3.3 V through a resistor of 1k to 10k Ohms.
To debug, try tying the Arduino (I'm assuming Uno) reset to ground. Connect the ESP-01 Rx to Uno Rx and Tx to Tx.* This will hold the Uno processor in the reset state so you can just use only USB-Serial part of the Uno to watch what is going on when the ESP-01 boots. To make the ESP-01 reboot, touch the ESP-01 RST pin to ground. With the Arduino Serial Monitor set the baud rate to 74880 which is typically used during ESP-01 boot. Normal behavior is for the ESP-01 to output some boot message and sit waiting for AT commands. If it continuously reboots (which I suspect might be your issue) you probably have a power problem.
If the ESP-01 seems to boot ok, you can then change the Serial Monitor baud rate to 9600 (or maybe 115200) and send AT commands to the ESP-01.
Edded to add serial connection guidance as per Juraj's post #7.
MrMark:
To debug, try tying the Arduino (I'm assuming Uno) reset to ground. This will hold the Uno processor in the reset state so you can just use only USB-Serial part of the Uno to watch what is going on when the ESP-01 boots. To make the ESP-01 reboot, touch the ESP-01 RST pin to ground. With the Arduino Serial Monitor set the baud rate to 74880 which is typically used during ESP-01 boot. Normal behavior is for the ESP-01 to output some boot message and sit waiting for AT commands. If it continuously reboots (which I suspect might be your issue) you probably have a power problem.
