Espe8266 wifi serve alguem ajuda!
ESTOU TENTANDO USAR UM TEMPORIZADOR MILLIS OU OUTRO MAS NAO FUNCIONA QUANDO COLOCO NO CODIGO WIFIWEBSERVE E SOU NOVATO EM ARDUINO E ESP, E SE ALGUEM TIVER UM TEMPORIZADOR MELHOR SERIA BOM??
#include <ESP8266WiFi.h>
#ifndef STASSID
#define STASSID "KNUPFER"
#define STAPSK "0800.com"
#define pino1 D3
#define pino2 D4
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
int RELE1 = 2;
int RELE2 = 2;
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  // RELE LIGA DESLIGA
  pinMode (pino1, OUTPUT);
  pinMode (pino2, OUTPUT);
  // Connect to WiFi network
  Serial.print(F("Connecting to "));
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(F("."));
  Serial.println(F("WiFi connected"));
  // Start the server
  server.begin();
  Serial.println(F("Server started"));
  // Print the IP address
  // Check if a client has connected
  WiFiClient client = server.accept();
  if (!client) { return; }
  Serial.println(F("new client"));
  client.setTimeout(5000);  // default is 1000
  // Read the first line of the request
  String req = client.readStringUntil('\r');
  Serial.println(F("request: "));
  Serial.println(req);
     //RELE 1 FUNCINANDO recebe dados app////////////////////
     if (req.indexOf(F("/RELE1/ON")) != -1) {
      RELE1 =1;
      if (req.indexOf(F("/RELE1/OFF")) != -1) {
      RELE1 =2;
        //RELE 2  RECEBE DADOS///////////////////////////
         if (req.indexOf(F("/RELE2/ON")) != -1) {
      RELE2 =1;
      if (req.indexOf(F("/RELE2/OFF")) != -1) {
      RELE2 =2;
     //aplica dados RELE 1//////////////////////////
   if (RELE1 == 1){
    digitalWrite( pino1, HIGH);
    if (RELE1 == 2) {
     digitalWrite( pino1, LOW);
     //aplica dados RELE 2//////////////////////////
    if (RELE2 == 1){
    digitalWrite( pino2, HIGH);
    if (RELE2 == 2) {
   digitalWrite( pino2, LOW);
  // read/ignore the rest of the request
  // do not client.flush(): it is for output only, see below
  while (client.available()) {
    // byte by byte is not very efficient
    client.read();
  // Send the response to the client
  // it is OK for multiple small client.print/write,
  // because nagle algorithm will group them into one single packet
  client.print(F("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nRAI SERVER "));
  client.print(F("<br><br>Click <a href='http://"));
  client.print(WiFi.localIP());
  client.print(F("/gpio/1'>here</a> to switch LED GPIO on, or <a href='http://"));
  client.print(F("/gpio/0'>here</a> to switch LED GPIO off.</html>"));
 // client.print(type="text/javascript"> var teste = "99");
  //client.print("<h1><center>" + String(xx) + "</center></h1>");
  // The client will actually be *flushed* then disconnected
  // when the function returns and 'client' object is destroyed (out-of-scope)
  // flush = ensure written data are received by the other side
  Serial.println(F("Disconnecting from client"));
   ///////////TESTE ENVIO
*PRIMEIRO TEMPORIZADOR ,E ESSE E UMA BELEZA SOZINHO *
 * Exemplo de código usando millis()
// Inicia variáveis de tempo
unsigned long millisTarefa1 = millis();
unsigned long millisTarefa2 = millis();
 int liga_ou_desligar1 = 1;
 int liga_ou_desligar2 = 1;
 long tempo1 = 5000;
 long tempo2 = 10000;
 unsigned long millisSegundo1 ;
 unsigned long millisSegundo2;
// Iniciação
void setup(){
  // Inicia comunicação na porta serial
  // Define pinos dos leds como saída
  pinMode(D4, OUTPUT);
  pinMode(D3, OUTPUT);
// Laço perpétuo
void loop(){
  // Executa tarefa 1
  tarefa1();
  tarefa2();
void tarefa1(){
  // Verifica se já passou 200 milisegundos
   if(liga_ou_desligar1 == 1){
         if((millis() - millisTarefa1) < tempo1){
            // Acende o led do pino 7
         digitalWrite(D4, HIGH);
           millisSegundo1 = ( tempo1 - (millis() - millisTarefa1 ));
             Serial.println(millisSegundo1 /1000);
         }else{
          // Apaga o led do pino 7
           digitalWrite(D4, LOW);
           }else if(liga_ou_desligar1==0){
void tarefa2(){
   if(liga_ou_desligar2 == 1){
         if((millis() - millisTarefa2) < tempo2){
         digitalWrite(D3, HIGH);
           millisSegundo2 = ( tempo2 - (millis() - millisTarefa2));
             Serial.println(millisSegundo2 /1000);
         }else{
           digitalWrite(D3, LOW);
           }else if(liga_ou_desligar2==0){
*2 TEMPORIZADOR MAIS ESSE E MEIO RUIM PRA MIN MAIS VOU MOSTRA ASSIM MESMO
#include <Crescer.h>
Tempora temp1;
Tempora temp2;
Tempora temp3;
int analogica;
int refr = 0;
int teste = 1;
int teste2 = 1;
int pisca = 0;
delay(5000);
Serial.println("teste     testeeeeeeeeeeeeeeeee");
temp1.defiSP(10000);
temp2.defiSP(7000);
temp3.defiSP(5000);
     Serial.println(".....");
  //Aguarda intervalo de tempo em milissegundos
  //Apaga o led
  Serial.println("...........");
  // if (temp1.Saida(1)){
     // Serial.println("teste      1111");
      // temp1.Saida(0);
       if(teste== 1 & temp1.Saida(1)){
            Serial.println("test 1111111111111111");
             temp1.Saida(0);
              teste = 0;
             if(teste2== 1 & temp2.Saida(1)){
            Serial.println("teste  22222222222222");
             temp2.Saida(0);
              teste2 = 0;
