Hi All:
Frustrating issue, have been using espressif espnow successfully with Generic ESP8266 dev boards. When trying to verify/compile for a ESP32 (Pico-D4 board) the compiler flags espnow.h as a file not found, tried other ESP32 boards - same issue.
Switching back to the ESP8266 board and all is good. I've closed and re-started the IDE, reinstalled the library, reinstalled the boards, etc. I even pulled out an old Win10 laptop - loaded the latest Arduino IDE, espnow library and boards - same compiling issue with the ESP32. Pretty stumped here!
Details:
- Arduino IDE 2.3.2 2/20/24 update
- Boards Mgr
- Esp8266 by ESP8266 ver 3.1.2 installed
- Esp32 by Espressif ver 2.0.14 installed (tried using older versions, no luck)
- Boards selected:
- Generic ESP8266 Module
- ESP32 Pico-D4
ESP32 compiling error: compilation terminated. exit status 1
Compilation error: espnow.h: No such file or directory
Test code below...
// ESP32 TEST TO GET ESPNOW.H TO BE RECONGIZED BY THE ARDUINO IDE COMPILER
#include <espnow.h>
uint8_t senderMac[] = { }; //NOT NEEDED
esp_now_init();
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
esp_now_register_recv_cb(onDataReceived);
void onDataReceived(uint8_t *senderMac, uint8_t *data, uint8_t len)
Serial.print("DATA RECEIVED: ");
