Hi everybody,
forgive me if it-s not the correct category for my post
I'm interfacing arduino Nano with a ENC28J60 LAN module to control multiple digital inputs via web on local network using the EtherCard.h library (I was not able to make my board work with other software)
Now I'm trying to assign a local domain name to my arduino server, such as /ledcontrol .
The purpose is be able to reach the arduino server webpage typing /ledcontrol in the browser instead the IP address.
Someone has experience with this ?
Thanks in advance
Uge
PS I attach my code here, it is very similar to examples on web
#include <EtherCard.h>
static byte mymac[] = {0xDD,0xDD,0xDD,0x00,0x00,0x01};
static byte myip[] = {192,168,1,200};
byte Ethernet::buffer[700];
const int ledPin = 4;
boolean ledStatus;
char* on = "ON";
char* off = "OFF";
char* statusLabel;
char* buttonLabel;
void setup () {
Serial.begin(57600);
Serial.println("WebLed Demo");
if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
Serial.println( "Failed to access Ethernet controller");
Serial.println("Ethernet controller initialized");
if (!ether.staticSetup(myip))
Serial.println("Failed to set IP address");
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
ledStatus = false;
word len = ether.packetReceive();
word pos = ether.packetLoop(len);
if(pos) {
if(strstr((char *)Ethernet::buffer + pos, "GET /?status=ON") != 0) {
Serial.println("Received ON command");
ledStatus = true;
if(strstr((char *)Ethernet::buffer + pos, "GET /?status=OFF") != 0) {
Serial.println("Received OFF command");
ledStatus = false;
if(ledStatus) {
digitalWrite(ledPin, HIGH);
statusLabel = off;
buttonLabel = on;
statusLabel = on;
buttonLabel = off;
BufferFiller bfill = ether.tcpOffset();
bfill.emit_p(PSTR("HTTP/1.0 200 OK\r\n"
"Content-Type: text/html\r\nPragma: no-cache\r\n\r\n"
"<html><head><title>WebLed</title></head>"
"<body>LED Status: $S "
"<a href=\"/?status=$S\"><input type=\"button\" value=\"$S\"></a>"
"</body></html>"
), statusLabel, buttonLabel, buttonLabel);
ether.httpServerReply(bfill.position());
