I am attempting to send an email containing an attachment with an ethernet shield.
I can send an email no problem, thanks to SurferTim, but I am having an issue with the attachment.
I have tried several ways and read many posts.
However, I cannot find a complete solution.
I can get a blank file to send and a file with canned text in it to send, but not the file on the SD Card.
Any assistance would be greatly appreciated.
The code I use is below. I removed the email addresses, passwords, etc.
Email client sketch for IDE v1.0.5 and w5100/w5200
Posted 7 May 2015 by SurferTim
Encoding Routines by Razorblade
https://www.base64encode.org/ Encoder Site
http://forum.arduino.cc/index.php?topic=296897.0 SurferTim's Addition Thread
http://forum.arduino.cc/index.php?topic=67701.30 Encoding Thread
#include <SD.h>
#include <SPI.h>
#include <EthernetV2_0.h> //Library for SEEED Ethernet Sheild Version 2.0
#define W5200_CS 10 //Denotes Pin 10 as W5200 Pin
#define SDCARD_CS 4 //Denotes Pin 4 as SD Card Pin
File SendFile;
static const char cb64[]="ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
//Mac must be unique
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
//Change network settings to yours**************************
IPAddress ip( 0, 0, 0, 0 );
IPAddress gateway( 0, 0, 0, 0 );
IPAddress subnet( 0, 0, 0, 0 );
char server[] = "mail.smtp2go.com";
int port = 80;
EthernetClient client;
Ethernet.begin(mac, ip, gateway, gateway, subnet);
delay(2000);
//Initialize SD Card
Serial.print("Initializing SD card...");
pinMode(W5200_CS, OUTPUT);
digitalWrite(W5200_CS,HIGH);
pinMode(SDCARD_CS,OUTPUT);
if (!SD.begin(SDCARD_CS)) {
Serial.println("Initialization Failed!");
return;
Serial.println("Initialization Successful");
Serial.println(F("Ready. Press 'e' to send."));
void loop(){
byte inChar;
inChar = Serial.read();
if(inChar == 'e'){
if(sendEmail()) Serial.println(F("Email Sent"));
else Serial.println(F("Email Failed"));
byte sendEmail(){
byte thisByte = 0;
byte respCode;
if(client.connect(server,port) == 1){
Serial.println(F("Connected"));
else {
Serial.println(F("Connection Failed"));
return 0;
if(!eRcv()) return 0;
Serial.println(F("Sending Hello"));
//replace 1.2.3.4 with your Arduino's ip**************************
client.println("EHLO 1.2.3.4");
Serial.println(F("Sending authorizes login"));
client.println("auth login");
Serial.println(F("Sending User"));
//Change to your base64 encoded user**************************
client.println("MyUserName");
Serial.println(F("Sending Password"));
//change to your base64 encoded password**************************
client.println("MyPassword");
//change to your email address (sender)**************************
Serial.println(F("Sending From"));
client.println("MAIL From: <Sender@gmail.com>");
//change to recipient address**************************
Serial.println(F("Sending To"));
client.println("RCPT To: <Reciever@gmail.com>");
Serial.println(F("Sending DATA"));
client.println("DATA");
Serial.println(F("Sending email"));
client.println("To: You <Reciever@gmail.com>");
//change to your address**************************
client.println("From: Me <Sender@gmail.com>");
client.write("Subject: Arduino email test");
//Start of Attach File
client.write("MIME-Version: 1.0\r\n");
client.write("Content-Type: Multipart/mixed; boundary=frontier\r\n\r\n");
client.write("--frontier\r\n");
client.write("Content-Type: text/plain\r\n\r\n");
client.write("This is from my Arduino!\r\n");
client.write("Content-Type: text/plain\r\n");
//This is where you would send your file
SendFile =SD.open("test.txt",FILE_READ);
client.print("Content-Type: text/plain; name=\"test.txt\"\r\n");
client.print("Content-Transfer-Encoding: base64\r\n");
client.write("Content-Disposition: attachment; filename=\"test.txt\"\r\n\r\n");
client.write("\r\n--frontier--\r\n");
encode();
SendFile.close();
//End of Attach File
client.write(".\r\n");
Serial.println(F("Sending QUIT"));
client.println("QUIT");
client.stop();
Serial.println(F("disconnected"));
return 1;
byte eRcv(){
byte respCode;
byte thisByte;
int loopCount = 0;
while(!client.available()){
delay(1);
loopCount++;
// if nothing received for 10 seconds, timeout
if(loopCount > 10000) {
client.stop();
Serial.println(F("\r\nTimeout"));
return 0;
respCode = client.peek();
while(client.available()){
thisByte = client.read();
Serial.write(thisByte);
if(respCode >= '4'){
efail();
return 0;
return 1;
void efail(){
byte thisByte = 0;
int loopCount = 0;
client.println(F("QUIT"));
while(!client.available()) {
delay(1);
loopCount++;
client.stop();
return;
client.stop();
Serial.println(F("isconnected"));
void encodeblock(unsigned char in[3],unsigned char out[4],int len) {
out[0]=cb64[in[0]>>2]; out[1]=cb64[((in[0]&0x03)<<4)|((in[1]&0xF0)>>4)];
out[2]=(unsigned char) (len>1 ? cb64[((in[1]&0x0F)<<2)|((in[2]&0xC0)>>6)] : '=');
out[3]=(unsigned char) (len>2 ? cb64[in[2]&0x3F] : '=');
void encode() {
unsigned char in[3],out[4];
int i,len,blocksout=0;
while (SendFile.available()!=0) {
len=0;
for (i=0;i<3;i++){
in[i]=(unsigned char) SendFile.read();
if (SendFile.available()!=0) len++;
else in[i]=0;
if (len){
encodeblock(in,out,len);
for(i=0;i<4;i++) client.write(out[i]);
blocksout++;
if (blocksout>=19||SendFile.available()==0){
if (blocksout) client.print("\r\n"); blocksout=0;
Below is what I get in the Serial Monitor
Initializing SD card...Initialization Successful
Connected
220 mail.smtp2go.com ESMTP Exim 4.85 Thu, 05 Nov 2015 08:15:19 +0000
Sending Hello
250-mail.smtp2go.com Hello 1.2.3.4 [1.2.3.4]
250-SIZE 52428800
250-8BITMIME
250-PIPELINING
250-AUTH CRAM-MD5 PLAIN LOGIN
250-STARTTLS
250 HELP
334 VXNlcm5hbWU6
Sending User
334 UGFzc3dvcmQ6
Sending Password
235 Authentication succeeded
Sending From
250 OK
Sending To
250 Accepted <Reciever@gmail.com>
Sending DATA
354 Enter message, ending with "." on a line by itself
Sending email
250 OK id=1ZuFhY-NRKL38-Jx
Sending QUIT
221 mail.smtp2go.com closing connection
disconnected
Email Sent
Thanks
