Ethernet SD Wont recognize
fat16lib:
Also some pairs of libraries are incompatible. For example the old version of SdFat used in SD.h only sets SPI options in the begin call. If the second library changes SPI options the SD library may fail later.
I've often wondered why there is a global SPI object. If each library had its own object then presumably it would be possible to simultaneously use SPI devices with different mode numbers (CPOL, CPHA), possibly with a small loss in performance?
SdFat and several other libraries now initialize the SPI bus before every access, setting speed and mode. The overhead is small and sharing the SPI bus works much better.
Unfortunately SD.h is based on a very old version of SdFat that has a number of bugs and problems. The Arduino developers never contact me and are maintaining SD.h so my bug fixes and mods never get into SD.h.
