Hi everyone, I'm starting using Arduino for a project involving the ethernet shield
I have an Arduino Uno with a Ethernet Shield 2 , unfortunately the shield doesn't seem to be working.
All the relevant leds on the shield are ok, I tried this simple sketch which I found somewhere else on the forum to test if the interface is correct:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0xF8, 0x6D };
IPAddress ip(192, 168, 44, 176);
// disable SD SPI
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
// Start ethernet
Serial.println(F("Starting ethernet..."));
Ethernet.begin(mac, ip);
Serial.println(Ethernet.localIP());
delay(2000);
Serial.println(F("Ready"));
I get this in the serial monitor:
0.176.176.176
Ready
which surely isn't the ip I need, and it never changes regardless of the IP I try to set. I already checked 3 times the pin connection between the two boards, it surely is ok.
Should I just give up and substitute the ethernet shield ?
TIA
Claudio
When you say ethernet shield 2, do you mean 2.0? Like this one with a w5200 IC?
If so, you need to use the library for the w5200.
I mean the one with the W5500 controller, isn't the standard ethernet library enough? I found no mention of a different library anywhere...
Bye
The standard ethernet library is not enough.The Wiznet w5500 is closer to the w5200.
http://wizwiki.net/wiki/doku.php?id=products:w5500:migration
I would try the w5200 library.
I solved it in a rather easy way, I tried the ethernet2 library and everything is ok now.
I guess it would be better if this was written in the shield data sheet or the description, but anyway I'm just too happy to care .
Thank you for the suggestion, it pointed me to the library matter.
CiBi69:
Dear CiBi69, can you share the link of the "ethernet2 library"? I have exactly the same error you reported. Thanks for your help!
Chris.
CiBi69
June 26, 2015, 7:33am
7
Hi Chris,
the ethernet2 library is included in the arduino software, you can find it in the Import library menu item, menu Sketch.
Ciao
Claudio.
CiBi69:
Hi Chris,
Ciao
Claudio.
You must mean the IDE from Arduino.org , not Arduino.cc. Different websites. It is not included in the IDE from this website.
CiBi69:
Hi Chris,
Ciao
Claudio.
Ciao Claudio, thanks for your answer!
I must add that I solved the problem I had.
I just had to update the IDE to 1.7.4 which includes the "Ethernet 2" library and everything worked out!.
Look forward to any comment.
Thanks everyone.
Bye / Ciao / Adios!
Chris.
Makes you wonder why the Arduino.cc crew can't upgrade their ethernet library, doesn't it?
