Hello,
I wrote a program for reading the RFID cards and everything works properly , now I need to save the readings to a file and send the data to a server.
So I bought one ethernet shield, after having copied the collementi not work anymore .
I read that there is a conflict , however, the pin does not know how to solve it .
Can you help me?
Thank you
ITALIANO
Salve,
Ho scritto un programma per la lettura delle tessere rfid e funziona tutto correttamente, ora ho bisogno di salvare le letture su un file e inviare i dati ad un server.
Ho comprato quindi uno scudo ethernet , dopo aver ricopiato i collementi non funziona più niente.
Ho letto che c'è un conflitto di pin però non so come risolverlo.
Potete aiutarmi?
Grazie
If you're using the Arduino-made ethernet shield, communication to both the SD card and to the ethernet chip is conducted via SPI. The RC522 also uses SPI, so that could cause a conflict.
As I understand, the Ethernet Shield uses pin 4 to select the SD card and pin 10 to select the Ethernet chip - if these are being used by the RFID chip or anything else, that will also cause a problem.
If you want to help me speak civilly and not fool me , otherwise it ignores it like other people who saw the post and did not respond .
If I'm asking for your help I am because I may not have so much knowledge !
So if you tell me how to solve the conflict between the legs of the two components well otherwise you shut up please!
