I know it might sound like an old topic and even already solved but I've been looking for a solution without success.
I cant interface my Arduino w/ethernetshield and my router, I've tried disabling firewalls, opening ports but I cant get it to work.
this is my code please help me.....
#include <SPI.h>
#include <Ethernet.h>// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,1,120 };
byte server[] = { 173,194,33,104 }; // Google
byte gateway[] ={ 192, 168, 1, 254 };// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
Client client(server, 80);void setup() {
// start the Ethernet connection:
Ethernet.begin(mac, ip, gateway);
// start the serial library:
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");// if you get a connection, report back via serial:
if (client.connect()) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.0");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
}void loop()
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
}// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();// do nothing forevermore:
for(;
