So before you ask, i have done every research and im helpless. I tried to do the BASIC blinking LED thing, but it only works on Pin 13. Ever other Pin wont respond.
What happens if you connect the LED and resistor directly across 5V and GND ? Does the LED light up ?
If you are using a breadboard and have power connected to the long stips down each side then are the colored lines associated with them continuous or do they have a break in them ? If they have a break and you are connecting power to one end and components to the other you need to bridge the gaps with jumpers
When you tested it, you DID use a resistor, correct? Wiring a LED from 5V to GND with no resistor will work...ONCE...BRIEFLY(or not at all, if you have it backwards).
From the "somebody has to ask the dumb question" department. When you changed the code to pin 13 to pin 7, you uploaded the updated code, not just verified it, correct?
