Example code issues for Uno Q
I am noticing the example codes all use Serial, rather than Monitor, which results in no output on the Serial Monitor.
For example:
    How to interact with external SDRAM on Portenta H7
    The board comes with an hefty 8MB of external fast RAM, which can be used:
    - as a framebuffer (raw mode)
    - as an expansion of on-chip RAM to store "standard" data
    This example shows both the usages
#include "SDRAM.h"
void nonFrameBuffer() {
    // Initilize SDRAM for non-framebuffer operations
    SDRAM.begin(); // is the same as SDRAM.begin(SDRAM_START_ADDRESS);
    // Now we can malloc() and free() in the whole RAM space
    // For example, let's create a 7MB array
    uint8_t* myVeryBigArray = (uint8_t*)SDRAM.malloc(7 * 1024 * 1024);
    // and a small one
    uint8_t* mySmallArray = (uint8_t*)SDRAM.malloc(128);
    // and use then as usual
    for (int i = 0; i<128; i++) {
        myVeryBigArray[i] = i;
        mySmallArray[i] = i*2;
    // free the memory when you don't need them anymore
    SDRAM.free(myVeryBigArray);
void frameBuffer() {
    // In case we want a framebuffer-like area at the beginning of the flash,
    // simply initialize the memory as
    SDRAM.begin(SDRAM_START_ADDRESS + 2 * 1024 * 1024);
    // 2MB of contiguous memory available at the beginning
    uint32_t* framebuffer = (uint32_t*)SDRAM_START_ADDRESS;
    // We can't allocate anymore the huge 7MB array
    if (myVeryBigArray == NULL) {
        Serial.println("Oops, too big :)");
    while (!Serial);
    frameBuffer();
    // Uncomment to test the other functionality
    // nonFrameBuffer();
    // Sort of memtest for stability, useful for testing when overclocking
    if (SDRAM.test()) {
        Serial.println("SDRAM completely functional");
Yes, I understand it came from Portenta H7 example code, but it’s a relatively easy QoL fix.
Chang all Serial objects to Monitor and include this line: #include<Arduino_RouterBridge.h> in the sketch.
Yes. I know that, I’m just wondering if there is a way to apply this fix to the core itself so EVERYONE’s example code for this board actually work on this board.
