Example for converting char to byte using byte() conversion function
Dear all,
I am trying to convert a char array to a byte array. I need to use this byte array as pipe addresses for nRF24L01 module.
I referred to Arduino's documentation on byte() function to convert any data type to byte. Although it looks promising, it is not supported with an example.
Has anyone used this function before? I appreciate your help.
Thanks,
Raj
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it is not an Introductory Tutorial
byte mybyte = byte(whatever);
You don't need convert it because the byte array and char array are compatible.
Please show the code where you encountered with problem
Thanks for your response.
I tried the following but it didn't work, do you spot any errors?
// Converting char array to byte array
void setup(){
  char whatever []= "NEW01"; // new pipe address
  byte mybyte [6]= byte(whatever); // converting char to byte
void loop(){
Please note that I am fairly new to Arduino. I appreciate your continued support.
byte mybyte [5];      // we don't need the place for string terminator in the byte array
memcpy(mybyte,whatever,5);
Please do not post screenshots of error messages. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags.
char, byte and uint8_t all refer to an 8 bit value
Reading that makes me think that you have an array of chars like
char charArray[] = {'1', '2', '3'};
and want to convert it or copy it to an array of bytes like
byte byteArray[] = {1, 2, 3};
If that is not what you are trying to do then please provide an example of before and after as above
