I would appreciate a working example setting / overriding the Core Log Level (e.g. to info) when compiling my sketch using GitHub Action compile-sketch and Arduino CLI.
I have tried
libraries: |
- name: log4arduino
- name: ArduinoJson
cli-compile-flags: |
- --log-level
- info
- --output-dir
- ./build
- --build-property
- "compiler.c.extra_flags=-DVERSION=\"ci-SNAPSHOT\" -DCORE_DEBUG_LEVEL=3"
- --build-property
- "compiler.cpp.extra_flags=-DVERSION=\"ci-SNAPSHOT\" -DCORE_DEBUG_LEVEL=3"
sketch-paths: .
but without any luck. I can see in the build logs that CORE_DEBUG_LEVEL is being set twice, and not with my value last.
-Wextra -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ESP32C3_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32C3_DEV\"" "-DARDUINO_VARIANT=\"esp32c3\"" -DARDUINO_PARTITION_default "-DVERSION=\"0.7.7\"" -DCORE_DEBUG_LEVEL=3 -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/tmp/arduino-sketch-3D54A62C537BF9DEC041C07883B6DD14/build_opt.h
Hi @sosandstrom . Please provide the value of the fqbn input from your workflow.
include:
- arduino-platform: "esp32:esp32"
fqbn: "esp32:esp32:esp32c3"
"Core Debug Level " is a custom board option . Custom board options can be set via the FQBN.
The format of the FQBN is like this:
<vendor ID>:<architecture>:<board ID>[:<menu ID>=<option ID>[,<menu ID>=<option ID>]...]
You can learn all the available menu IDs and option IDs for a given board by running the following arduino-cli command :
arduino-cli board details --fqbn <FQBN>
(where <FQBN> is replaced by the fully qualified board name of the board you are using)
For example:
$ arduino-cli board details -b esp32:esp32:esp32c3
Board name: ESP32C3 Dev Module
FQBN: esp32:esp32:esp32c3
Board version: 2.0.5
Package name: esp32
Package maintainer: Espressif Systems
Package URL: https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
Package website: https://github.com/espressif/arduino-esp32
Package online help: http://esp32.com
Platform name: esp32
Platform category: ESP32
Platform architecture: esp32
Platform URL: https://github.com/espressif/arduino-esp32/releases/download/2.0.5/esp32-2.0.5.zip
Platform file name: esp32-2.0.5.zip
Platform size (bytes): 260916106
Platform checksum: SHA-256:c7a1040c5f007a799ef9eb249508e3544c3cf5246f67cdfdc1e80f7d0ca7b41d
Required tool: esp32:riscv32-esp-elf-gcc gcc8_4_0-esp-2021r2-patch3
Required tool: esp32:xtensa-esp32-elf-gcc gcc8_4_0-esp-2021r2-patch3
Required tool: esp32:xtensa-esp32s2-elf-gcc gcc8_4_0-esp-2021r2-patch3
Required tool: esp32:xtensa-esp32s3-elf-gcc gcc8_4_0-esp-2021r2-patch3
Required tool: esp32:esptool_py 4.2.1
Required tool: esp32:mkspiffs 0.2.3
Required tool: esp32:mklittlefs 3.0.0-gnu12-dc7f933
Option: USB CDC On Boot CDCOnBoot
Disabled ✔ CDCOnBoot=default
Enabled CDCOnBoot=cdc
Option: Partition Scheme PartitionScheme
Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS) ✔ PartitionScheme=default
Default 4MB with ffat (1.2MB APP/1.5MB FATFS) PartitionScheme=defaultffat
8M with spiffs (3MB APP/1.5MB SPIFFS) PartitionScheme=default_8MB
Minimal (1.3MB APP/700KB SPIFFS) PartitionScheme=minimal
No OTA (2MB APP/2MB SPIFFS) PartitionScheme=no_ota
No OTA (1MB APP/3MB SPIFFS) PartitionScheme=noota_3g
No OTA (2MB APP/2MB FATFS) PartitionScheme=noota_ffat
No OTA (1MB APP/3MB FATFS) PartitionScheme=noota_3gffat
Huge APP (3MB No OTA/1MB SPIFFS) PartitionScheme=huge_app
Minimal SPIFFS (1.9MB APP with OTA/190KB SPIFFS) PartitionScheme=min_spiffs
16M Flash (2MB APP/12.5MB FATFS) PartitionScheme=fatflash
16M Flash (3MB APP/9.9MB FATFS) PartitionScheme=app3M_fat9M_16MB
RainMaker PartitionScheme=rainmaker
Option: CPU Frequency CPUFreq
160MHz (WiFi) ✔ CPUFreq=160
80MHz (WiFi) CPUFreq=80
40MHz CPUFreq=40
20MHz CPUFreq=20
10MHz CPUFreq=10
Option: Flash Mode FlashMode
QIO ✔ FlashMode=qio
DIO FlashMode=dio
QOUT FlashMode=qout
DOUT FlashMode=dout
Option: Flash Frequency FlashFreq
80MHz ✔ FlashFreq=80
40MHz FlashFreq=40
Option: Flash Size FlashSize
4MB (32Mb) ✔ FlashSize=4M
8MB (64Mb) FlashSize=8M
2MB (16Mb) FlashSize=2M
16MB (128Mb) FlashSize=16M
Option: Upload Speed UploadSpeed
921600 ✔ UploadSpeed=921600
115200 UploadSpeed=115200
256000 UploadSpeed=256000
230400 UploadSpeed=230400
512000 UploadSpeed=512000
Option: Core Debug Level DebugLevel
None ✔ DebugLevel=none
Error DebugLevel=error
Warn DebugLevel=warn
Info DebugLevel=info
Debug DebugLevel=debug
Verbose DebugLevel=verbose
Option: Erase All Flash Before Sketch Upload EraseFlash
Disabled ✔ EraseFlash=none
Enabled EraseFlash=all
Programmers: Id Name
esptool Esptool
Here we can see that the ID for the "Core Debug Level " menu is DebugLevel and the ID for the "Info " option is info.
So the full FQBN is:
esp32:esp32:esp32c3:DebugLevel=info
So just replace the esp32:esp32:esp32c3 in your workflow with esp32:esp32:esp32c3:DebugLevel=info and you are set. No need to mess around with adding --build-property flags .
The "extra_flags" properties like compiler.cpp.extra_flags are useful in cases where you need to add arbitrary additional flags to the compilation commands, but in cases like this where you have a dedicated formal API provided by the Arduino boards platform author and framework, using that property instead of setting the custom board option is super hacky.
Please let me know if you have any questions or problems.
Thanks @ptillisch for the prompt and detailed response!
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
system
Closed
March 26, 2023, 1:51pm
7
