6. restart Arduino, Excel,PC .
7. tried it on Excel 2010 and Excel 365.
8. when i tried open serial port after data streamer connect to Excel , i get error message. same when i tried connect data streamer when serial terminal open in the IDE. for my understanding it's mean it recognized each other .
no data shogun in the Excel .
help !!!
thanks
Your topic has been moved to a more suitable location on the forum. Please read the sticky topics in Uncategorized - Arduino Forum why you should not have posted in "Uncategorized".
that what i did ,and that why i did I choose this add-on Excel Data streamer . in all the example i find
it works . i looking for if someone faced this problem and how it was solved.
I don’t think you can have the IDE and excel using the same com port as excel at the same time .
When you switch off /on you need to check your Arduino is connected to the same com port as excel . I’m unsure that virtual com port is it , I would expect the same name as windows shows in device manager .
Plug/unplug your Arduino see if that changes .
I take it the excel add in loaded up ok .
I’ve never used this as my version of excel is too old , so I send to an SD card then import that file into excel.
