expected ';' before '{' token
I get an expected ';' before '{' token error when trying to compile my code.
It appears on the first line of the following section
else(distance>=40){
  StepsRequired  = 0;
  steppermotor.setSpeed(700);
  steppermotor.step(StepsRequired);
I aim to have a stepper motor stop if distance value received from an ultrasonic sensor is more than 40cm, move clockwise between 30-40 cm, and counter clockwise 0-30cm.
The problem seems to lie with else, as I can compile fine if this is removed.
Any suggestions?
Problem occurs near end of code:
#include <Stepper.h>
// STEPPER CONSTANTS
// Number of steps per internal motor revolution
const float STEPS_PER_REV = 32;
//  Amount of Gear Reduction
const float GEAR_RED = 64;
// Number of steps per geared output rotation
const float STEPS_PER_OUT_REV = STEPS_PER_REV * GEAR_RED;
// Define Variables
// Number of Steps Required
int StepsRequired;
Stepper steppermotor(STEPS_PER_REV, 8, 10, 9, 11);
// SENSOR CONSTANTS
// defines pins numbers
const int trigPin = 12;
const int echoPin = 13;
// defines variables
long duration;
int distance;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
Serial.begin(9600); // Starts the serial communication
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
if(distance<=30){
  StepsRequired  =  - STEPS_PER_OUT_REV / 20;
else if(distance>30){
  StepsRequired  = STEPS_PER_OUT_REV / 20;
else(distance>=40){
  StepsRequired  = 0;
The code you posted wouldn't cause that error because it's just a bit unterminated comment. Please make sure to post the same code to the forum as the code you're compiling.
As for the error, please take a little time to study the reference page for else to understand how to use it correctly:
You have a instruction after else
it must always be in the form
"} else {"
you need to be using "else if"
Cheetor:
"} else {"
Thanks!
Replacing else with else if solved the error.
The result still wasn't what I wanted, but it worked after I changed the order of my code.
The following code works.
// Define Constants
// Define Variables
int StepsRequired;
long duration;
int distance;
if(distance>=40){
  StepsRequired  = 0;
else if(distance<=30){
