I have one last detail / complication to understand before my project is finished. The servo Part works when it is a stand alone / all by itself when it is on the UNO, but red lines at line 137. Since it is a servo signal it has to be PWM. Ideas on a way to overcome this challenge will be very welcome. It is the very last piece of my puzzle, Thanks in advance.
// ATtiny85 torch detector
// Author: Nick Gammon
// Date: 25 February 2015
// ATMEL ATTINY 25/45/85 / ARDUINO
// Pin 1 is /RESET
// Ain0 (D 5) PB5 1| |8 Vcc
// Ain3 (D 3) PB3 2| |7 PB2 (D 2) Ain1
// Ain2 (D 4) PB4 3| |6 PB1 (D 1) pwm1
// GND 4| |5 PB0 (D 0) pwm0
Pin 2 (PB3) <-- LDR (GL5539) --> Pin 7 (PB2) <----> 56 k <----> Gnd
Pin 5 (PB0) <---- LED ---> 100 R <-----> Gnd
#include <avr/sleep.h> // Sleep Modes
#include <avr/power.h> // Power management
#include <avr/wdt.h> // Watchdog timer
#include <Servo.h>
Servo servo1;
int servoPin = 9;
const byte POWER_PIR = 7;
const byte PIR_SIGNAL = 12;
int val = 0;
const byte LED = 13;
const byte LDR_ENABLE = 8;
const byte LDR_READ = A0;
const int LIGHT_THRESHOLD = 200; // Flash LED when darker than this
// when ADC completed, take an interrupt
EMPTY_INTERRUPT (ADC_vect);
float getReading (byte port) // Take an ADC reading in sleep mode (ADC)
power_adc_enable() ;
ADCSRA = bit (ADEN) | bit (ADIF); // enable ADC, turn off any pending interrupt
// set a2d prescale factor to 128
// 8 MHz / 128 = 62.5 KHz, inside the desired 50-200 KHz range.
ADCSRA |= bit (ADPS0) | bit (ADPS1) | bit (ADPS2);
if (port >= A0)
port -= A0;
#if defined(__AVR_ATmega328P__)
ADMUX = bit (REFS0) | (port & 0x07); // AVcc
#endif
noInterrupts ();
set_sleep_mode (SLEEP_MODE_ADC); // sleep during sample
sleep_enable();
// start the conversion
ADCSRA |= bit (ADSC) | bit (ADIE);
interrupts ();
sleep_cpu ();
sleep_disable ();
// reading should be done, but better make sure
// maybe the timer interrupt fired
// ADSC is cleared when the conversion finishes
while (bit_is_set (ADCSRA, ADSC))
byte low = ADCL;
byte high = ADCH;
ADCSRA = 0; // disable ADC
power_adc_disable();
return (high << 8) | low;
} // end of getReading
// watchdog interrupt
ISR (WDT_vect)
wdt_disable(); // disable watchdog
} // end of WDT_vect
#define watchdogRegister WDTCSR
//#else
// #define watchdogRegister WDTCSR
#endif
void setup ()
wdt_reset();
pinMode (POWER_PIR, OUTPUT);
pinMode (LED, OUTPUT);
servo1.attach(servoPin);
pinMode (LDR_ENABLE, OUTPUT);
pinMode (PIR_SIGNAL, INPUT);
ADCSRA = 0; // turn off ADC
power_all_disable (); // power off ADC, Timer 0 and 1, serial interface
} // end of setup
void loop ()
// power up the LDR, take a reading
digitalWrite (LDR_ENABLE, HIGH);
int value = getReading (LDR_READ);
// power off the LDR
digitalWrite (LDR_ENABLE, LOW);
if (value < LIGHT_THRESHOLD) // if it's dark, do stuff
power_timer0_enable ();
delay (1); // let timer reach a known point
digitalWrite (POWER_PIR, HIGH);
} else
digitalWrite (POWER_PIR, LOW);
{ val = digitalRead (PIR_SIGNAL); // read the input pin
digitalWrite (LED,val); // sets the LED to the button's value
void analogWrite(uint8_t, int)
servo1.write(0); //degrees
delay(50); // delay between moves
servo1.write(10);
delay(50);
servo1.write(0);
delay(50);
servo1.write(10);
delay(50);
power_timer0_disable ();
goToSleep ();
} // end of loop
void goToSleep ()
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
noInterrupts (); // timed sequence coming up
// pat the dog
wdt_reset();
// clear various "reset" flags
MCUSR = 0;
// allow changes, disable reset, clear existing interrupt
watchdogRegister = bit (WDCE) | bit (WDE) | bit (WDIF);
// set interrupt mode and an interval (WDE must be changed from 1 to 0 here)
watchdogRegister = bit (WDIE) | bit (WDP2) | bit (WDP1) | bit (WDP0); // set WDIE, and 2 seconds delay
sleep_enable (); // ready to sleep
interrupts (); // interrupts are required now
sleep_cpu (); // sleep
sleep_disable (); // precaution
} // end of goToSleep
It's PIR dependent, I tried analogWrite (servo1, val) I. think I am missing the 0-255, I'm missing something. it's supposed to run when the PIR goes high / has an output signal.
//void analogWrite(uint8_t, int)
servo1.write(10);
delay(50);
servo1.write(0);
delay(50);
servo1.write(10);
delay(50);
Because you have added the void data type before the name of the function it looks like you are trying to define the function rather than call the function
Elsewhere in the sketch you have used
digitalWrite(LED, val); // sets the LED to the button's value
Oh look. No data type in front of the function name
This is weird....... The servo sketch works fine with the parameters used as a stand alone program. How ever if I comment out all the PIR read, light LED stuff and just include the servo positions with delays it doesn't do anything. Is there perhaps a library conflict?
Not quite sure I understand the meaning of that, but this works. the servo is commented out. But is says :
digitalWrite (LED,val); which basically means if the PIR goes HIGH so does the LED. OR.....our we on 2 completely different pages?
// Pin 1 is /RESET
#include <Servo.h>
Servo servo1;
int servoPin = 9;
int val = 0;
if (port >= A0)
port -= A0;
#endif
noInterrupts ();
sleep_enable();
interrupts ();
sleep_cpu ();
sleep_disable ();
byte low = ADCL;
byte high = ADCH;
ISR (WDT_vect)
//#else
#endif
void setup ()
wdt_reset();
} // end of setup
void loop ()
} else
/*val = digitalRead (PIR_SIGNAL); // read the input pin
servo1.write(10);
delay(50);
servo1.write(0);
delay(50);
servo1.write(10);
delay(50);*/
goToSleep ();
} // end of loop
void goToSleep ()
// pat the dog
wdt_reset();
MCUSR = 0;
When you define a function to be used in a sketch you must specify what data type, if any, the function will return to the calling function. If no data is to be returned then you use the void data type
However, when you call a function you must not precede the function name with a data type otherwise the compiler will think that you are defining the function for which there are different requirements than when you define one
I strongly suggest that you read up on C/C++ functions
reading? It's straight from the Arduino ref library. Only I don't use a button, I use a PIR. I don't understand the confusion. It WORKS LIKE IT SAYS IT WILL! Something wanders in front of the PIR, The PIR sends out a digital signal, which is then read. as a HIGH, and then it turns on the LED. The "signal" from the PIR is set to last for 18 seconds, Then the signal goes low. and it turns off the LED. It isn't the PROBLEM
THE PROBLEM IS THE SERVO INSTRUCTIONS WHICH HAVE TO BE IMPLEMENTED WHEN THE PIR GOES HIGH! THEY DON'T WORK EVEN IF YOU COMMENT OUT ALL THE PIR STUFF AND SIMPLY SAY, "WHEN IT IS DARK MAKE THE SERVO DO THIS!"
SAMPLE CODE TAKEN FROM ARDUINO REF LIBRARY.
Example Code
Sets pin 13 to the same value as pin 7, declared as an input.
int ledPin = 13; // LED connected to digital pin 13
int inPin = 7; // pushbutton connected to digital pin 7
int val = 0; // variable to store the read value
pinMode(ledPin, OUTPUT); // sets the digital pin 13 as output
pinMode(inPin, INPUT); // sets the digital pin 7 as input
val = digitalRead(inPin); // read the input pin
digitalWrite(ledPin, val); // sets the LED to the button's value
If you have posted your sketch with that corrected then I missed it. If not then please post your code as it is now along with a schematic of your project. Preferably not a Fritzing picture. A photo of a hand drawn circuit is good enough
I will gladly do that tomorrow morning. I'm headed out to go fishing. Won't be back until the late AM hours. I draw really good too, BTW. ( mechanical draftsman, OLD SCHOOL, like they did 50 years ago, on a table) LOL, See you in the morning. Have a GREAT evening.
Good morning, Here is my current program with the servo portion in the loop commented out. So far, except for the servo part, everything works as anticipated. Attached you should find a schematic and the current code being used. As previously stated the servo code runs fine if it is uploaded to the uno, it is a relatively simple sketch and it does exactly what it is told to do. Note: Even if I comment out the PIR instructions, and put the servo routine in all by itself, absolutely NOTHING happens.
it means if it is dark the PIR turns on and reads the val which yes it all works
The problem is getting the servo to run at the same time the LED is turned on by the PIR Actually the problem is getting the servo to run at all.
It could be I'm using the wrong send servo signal pin JUST DOUBLE CHECKED 9 IS A PWM PIN
a conflict in timers
a conflict in libraries
COULD IT BE A HZ ISSUE
I know there's no condition written for the servo to work when the PIR goes high. But as stated, if you take the PIR and LED OUT of the equation, the servo still doesn't work.
The Servo library does not require that the pin used for the servo is PWM enabled
I suggest that you start by writing a sketch that makes the servo oscillate when an input is taken HIGH using a pushbutton or just a jumper to 5V. Once that works add the PIR code but not the LDR code and sleep, power and wdt code. Once that works add back the LDR code. Continue that way until either the sketch works as you want or you encounter a problem
This is where we run into a problem. i don't have a button so I am using the HIGH from the PIR. The second line of the loop, compile it, it's short and please explain what the error means so I can figure out how to fix it. I would greatly appreciate that.
#include <Servo.h>
Servo servo1;
int servoPin = 9;
int val = 0;
void setup(){
void loop(){
analogWrite (servo1,val); // sets the LED, or SERVO to the PIR's value**
servo1.write(0);
delay(50);
servo1.write(10);
delay(50);
servo1.write(0);
delay(50);
servo1.write(10);
delay(50);
Compilation error: cannot convert 'Servo' to 'uint8_t {aka unsigned char}' for argument '1' to 'void analogWrite(uint8_t, int)'
The error is telling you that the analogWrite() function expects a byte value (ie a pin number) as its first argument, not a servo object in this line of code
analogWrite(servo1, val); // sets the LED, or SERVO to the PIR's value**
In any case, you cannot control a servo using analogWrite()
