Code:
#include <dht.h>
dht DHT;
#define DHT11_PIN 7;
pinMode(13, OUTPUT);
if (DHT.temperature <= 26)
digitalWrite(13, HIGH);
delay(100);
Error:
sketch_mar29b:12: error: expected unqualified-id before 'if'
exit status 1
Got no idea whats causing this. I just started coding with Arduino today.
The if statement should be inside the void loop().
#include <dht.h>
dht DHT;
if (DHT.temperature <= 26) <<<<=========
delay(100);
Also remove the ; that you have after the }.
Tom...
I suggest you look in Examples in the IDE for example code that should come with that library.
Tom...
It worked!
#include <dht.h>
dht DHT;
#define DHT11_PIN 7
delay(100);
Left it as that. Thanks!
Gave you a karma for using code tags in your first post
