Expected unqualified-id before 'if'
Am I missing some loop brackets? Please see line in green which is returning Expected unqualified-id before 'if'
//Based on Example by Tom Igoe
#include <SD.h>
#include "Wire.h"
#define DS1307_ADDRESS 0x68
//Set by default for the SD Card Library
//MOSI = Pin 11
//MISO = Pin 12
//SCLK = PIN 13
//We always need to set the CS Pin
int CS_pin = 8;
int pow_pin = 8;
//IR Distance Sensor Pins
  int IR1_pin = 0;
float refresh_rate = 0.0;
  Wire.begin();
  Serial.println("Initializing Card");
  //CS Pin is an output
  pinMode(CS_pin, OUTPUT);
  //Card will Draw Power from Pin 8, so set it high
  pinMode(pow_pin, OUTPUT);
  digitalWrite(pow_pin, HIGH);
  //check if card is ready
  if (!SD.begin(CS_pin))
      Serial.println("Card Failure");
      return;
  Serial.println("Card Ready");
  //Read the Configuration information (COMMANDS.txt)
  File commandFile = SD.open("COMMANDS.txt");
  if (commandFile)
    Serial.println("Reading Command File");
    float decade = pow(10, (commandFile.available() - 1));
    while(commandFile.available())
      float temp = (commandFile.read() - '0');
      refresh_rate = temp*decade+refresh_rate;
      decade = decade/10;
    Serial.print("Refresh Rate = ");
    Serial.print(refresh_rate);
    Serial.println("ms");
    Serial.println("Could not read command file.");
    return;
{printDate();
byte bcdToDec(byte val)  {
// Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
void printDate(){
  // Reset the register pointer
  Wire.beginTransmission(DS1307_ADDRESS);
  byte zero = 0x00;
  Wire.write(zero);
  Wire.endTransmission();
  Wire.requestFrom(DS1307_ADDRESS, 7);
  int second = bcdToDec(Wire.read());
  int minute = bcdToDec(Wire.read());
  int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
  int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
  int monthDay = bcdToDec(Wire.read());
  int month = bcdToDec(Wire.read());
  int year = bcdToDec(Wire.read());
  //print the date EG   3/1/11 23:59:59
  Serial.print(month);
  Serial.print("/");
  Serial.print(monthDay);
  Serial.print("/");
  Serial.print(year);
  Serial.print(" ");
  Serial.print(hour);
  Serial.print(":");
  Serial.print(minute);
  Serial.print(":");
  Serial.println(second);
  int value = analogRead(IR1_pin);
[color=green][font=Verdana]  if (value > 375 || value < 300)[/font][/color]
     Serial.println(value);
     delay(500);   //wait half a second, then check again.
     //Open a file to write to
     //Only one file can be open at a time
     int IR1_val = Serial.println(value);
     File logFile = SD.open("LOG.txt", FILE_WRITE | O_APPEND);
     if (logFile)
        logFile.println(analogRead(IR1_pin));
       logFile.close();
The closing brace just above it ends the printdate function. That if is thus not in a function so the compiler is complaining
Thanks wildbill. It works!. I just need to bring the values down to my log.txt file. I hope it is easy!
