expected unqualified-id before numeric constant error
int green,9;
int gstate=HIGH;
int red,8;
int rstate,HIGH;
int pump,13;
int pstate=HIGH;
int button,1;
int buttoncurrent;
int buttonprev=LOW;
pinMode(green,OUTPUT);
pinMode(red,OUTPUT);
pinMode(pump,OUTPUT);
pinMode(button,INPUT);
Buttoncurrent=digitalRead(button);
if (buttoncurrent==HIGH&&buttonprev==LOW)
  if(rstate==HIGH)
    rstate=LOW;
    gstate=HIGH;
    rstate=HIGH;
    gstate=LOW;
digitalWrite(red,rstate);
digitalWrite(green,gstate);
buttonprev=bottoncurrent;
I have had problems with the error message before and decided to bite the bullet and fix it. I reinstalled the Arduino IDE and still had this problem. The end result should be a push button toggle , that starts on Red and when the button is pressed once the red will change Green. I am using a push button, Rgb LED, 330 resistor for the LED and a 10k for the push button. my error code is the following: Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
sketch_jan28a:1:11: error: expected unqualified-id before numeric constant
int green,9;
sketch_jan28a:3:9: error: expected unqualified-id before numeric constant
int red,8;
In file included from sketch\sketch_jan28a.ino.cpp:1:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:40:14: error: expected unqualified-id before numeric constant
#define HIGH 0x1
C:\Users\alexw\AppData\Local\Temp\arduino_modified_sketch_25108\sketch_jan28a.ino:4:12: note: in expansion of macro 'HIGH'
int rstate,HIGH;
sketch_jan28a:5:10: error: expected unqualified-id before numeric constant
int pump,13;
sketch_jan28a:7:16: error: expected unqualified-id before numeric constant
int pushbutton,1;
C:\Users\alexw\AppData\Local\Temp\arduino_modified_sketch_25108\sketch_jan28a.ino: In function 'void setup()':
sketch_jan28a:15:9: error: 'button' was not declared in this scope
C:\Users\alexw\AppData\Local\Temp\arduino_modified_sketch_25108\sketch_jan28a.ino:15:9: note: suggested alternative: 'ultoa'
ultoa
C:\Users\alexw\AppData\Local\Temp\arduino_modified_sketch_25108\sketch_jan28a.ino: In function 'void loop()':
sketch_jan28a:20:1: error: 'Buttoncurrent' was not declared in this scope
C:\Users\alexw\AppData\Local\Temp\arduino_modified_sketch_25108\sketch_jan28a.ino:20:1: note: suggested alternative: 'buttoncurrent'
buttoncurrent
sketch_jan28a:20:27: error: 'button' was not declared in this scope
C:\Users\alexw\AppData\Local\Temp\arduino_modified_sketch_25108\sketch_jan28a.ino:20:27: note: suggested alternative: 'ultoa'
ultoa
sketch_jan28a:38:12: error: 'bottoncurrent' was not declared in this scope
C:\Users\alexw\AppData\Local\Temp\arduino_modified_sketch_25108\sketch_jan28a.ino:38:12: note: suggested alternative: 'buttoncurrent'
buttoncurrent
exit status 1
option enabled in File -> Preferences.
Hello,
int green,9;
If you want to assign "9" to variable "green" then use "=" instead of ",". Else I have no idea what you are trying to do...
And, "buttoncurrent" is not the same as "Buttoncurrent" or "bottoncurrent"
