I've gone through the code with a magnifying glass, and reduced the number of errors. I tried to figure the last few out and checked the example codes as well, but 2-3 errors are present and I'm unable to figure it out.
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Nano, ATmega328P"
/Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino: In function 'void loop()':
flight_logger:99:17: error: redeclaration of 'long unsigned int age'
unsigned long age;
/Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino:66:17: note: 'long unsigned int age' previously declared here
unsigned long age;
flight_logger:100:65: error: no matching function for call to 'TinyGPS::crack_datetime(int*, byte*, byte*, byte*, byte*, long unsigned int*)'
gps.crack_datetime(&year, &month, &day, &minute, &second, &age);
In file included from /Users/Taran/Documents/Arduino/flight_logger/flight_logger.ino:4:0:
/Users/Taran/Documents/Arduino/libraries/TinyGPS/src/TinyGPS.h:83:8: note: candidate: void TinyGPS::crack_datetime(int*, byte*, byte*, byte*, byte*, byte*, byte*, long unsigned int*)
void crack_datetime(int *year, byte *month, byte *day,
/Users/Taran/Documents/Arduino/libraries/TinyGPS/src/TinyGPS.h:83:8: note: no known conversion for argument 6 from 'long unsigned int*' to 'byte* {aka unsigned char*}'
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: /Users/Taran/Documents/Arduino/libraries/Adafruit_SSD1306
Not used: /Users/Taran/Documents/Arduino/libraries/Adafruit_SSD1306_Wemos_Mini_OLED
exit status 1
option enabled in File -> Preferences.
code:
#include <SPI.h>
#include <Wire.h>
#include <TinyGPS.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <Adafruit_SSD1306.h>
// --------------------------------------------------------------------------initialising the display------------------------------------------------------------------------------------------------------------------------------------------------------
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define display_RESET -1 // since sharing reset pin with Arduino
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, display_RESET);
const int cs_sd = 2;
static const int RX = 3, TX = 4;
static const uint32_t gps_baud = 9600; // might need to change later on depending on sensitivity and speed requirements.
TinyGPS gps;
SoftwareSerial ss(RX, TX);
int speedMax = 0, speedCheck = 0;
int heightMax = 0, heightCheck = 0;
int satMax = 0, satCheck = 0;
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(15, 40);
display.write("VP-DK Avionics");
display.write("Flight Logger ver1.0");
delay(2000);
Wire.begin();
ss.begin(gps_baud);
if (!SD.begin(cs_sd)); {
display.write("Default Card.");
File data = SD.open("Flight Logger.txt", FILE_WRITE);
data.println(" "); data.println("Data acquisition started");
data.close();
byte date, time, chars = 0;
unsigned long age;
satCheck = (gps.satellites());
display.print("Max Speed: ");
display.print("Max Height: ");
display.println(" ");
speedCheck = float(gps.f_speed_kmph());
if (speedCheck > speedMax) {
speedMax = speedCheck;
display.setCursor(10, 80); // might have to change later
display.print(speedMax);
heightCheck = (gps.f_altitude());
if (heightCheck > heightMax) {
heightMax = heightCheck;
display.setCursor(50, 80); // might have to change later
display.print(heightMax);
display.setCursor(100, 80);
display.print(satCheck);
int year;
byte month, day, hour, minute, second, hundreths;
unsigned long age;
data_write = gps.crack_datetime(&year, &month, &day, &minute, &second, &age);
data.println(data_write);
data.close;
