Explaining bitwise operation
Can someone try and explain me or direct me to sites that do this following part of code:
for (int i = 0; i < 15; i++) {
    digitalWrite(s0, (i & 1));
    digitalWrite(s1, (i & 2) >> 1);
    digitalWrite(s2, (i & 4) >> 2);
    digitalWrite(s3, (i & 8) >> 3);
I understand the the result of the function is translating integer numbers to thier corresponding bit numbers(?)
I don't understand how is happening..
Tutorial:
Review & come back if needed...
Arduino Playground - BitMath
have a look at bitwise operators
You can eliminate the right shift operators in the code you posted, and it will work just as well.
I understand the operators:
(i & 1)
(i & 2)
i & 4)
(i & 8)
when i = 3 for example
i 0000 0011
1 0000 0001
result is 1 at s1. (lsb)
i 0000 0011
2 0000 0010
result is 1 at s2
i 0000 0011
4 0000 0100
result is 0 at s3.
i 0000 0011
8 0000 1000
result is 0 at s4.
when i = 7
i 0000 0111
1 0000 0001
result is 1 at s0
i 0000 0111
2 0000 0010
result is 1 at s1
i 0000 0111
4 0000 0100
result is 1 at s2.
i 0000 0111
8 0000 1000
result is 0 at s3.
I just can't understand the shifting part.
The shifting part simply moves the bit to the least significant bit position.
This isn't necessary in the case of digitalWrite.
It's equivalent to this
digitalWrite(s1, (i >> 1) & 1);
digitalWrite(s2, (i >> 2) & 1);
digitalWrite(s3, (i >> 3) & 1);
and also to this?
digitalWrite(s1, (i & 2));
digitalWrite(s2, (i & 4));
digitalWrite(s3, (i & 8));
No.
why is there? if it is not necessary how come is not badly effect the operation?
Because whoever wrote it wanted it to be "correct".
i 0000 0011
1 0000 0001
i 0000 0011
2 0000 0010
result is 1 at s2
i 0000 0011
4 0000 0100
result is 0 at s3.
i 0000 0011
8 0000 1000
result is 0 at s4.
when i = 7
i 0000 0111
1 0000 0001
result is 1 at s0
i 0000 0111
2 0000 0010
result is 1 at s1
i 0000 0111
4 0000 0100
result is 1 at s2.
i 0000 0111
8 0000 1000
result is 0 at s3.
is this not true? without the shifting part
For some values of !yes
or
int pins[] = {s0, s1, s2, s3};
    for (int b = 0; b < 4; b++) {
    digitalWrite(pins[b], bitRead(i, b) ? LOW : HIGH );
Technically, the interpretation of non-zero for HIGH, is not part of the API. It's just fortuitous. Also, taking the value of HIGH == 1. There is no guarantee that it will always be like that, it's only extremely likely.
But it's not, because it's still assuming HIGH==1
"Correct" would be like:
    digitalWrite(s2, (i & 4) ? HIGH:LOW);
It might be faster, too. multi-bit shifts on an AVR are slow. (sigh. It isn't)
Shoot, I always mix up the "sense" of the ternary op. :slight_smile: True comes first.
If someone complains that the previous solution also suffers from an assumption of non-zero==true, no, because it is defined for boolean expressions in the language.
Hence the " "correct" " :wink:
If we defined
byte a = 0b00010000;
a >> 1 will be 0b00001000
a >> 2 will be 0b00000100
a >> 3 will be 0b00000010
a >> 4 will be 0b00000001
