exponent
Hi
I have small problem with a calculation, if i hard code the formula in the program then it works but i need that i work with variables
my formula is
x = 4899e-2;
result x = 48.99
but i won't to have the main value in a variable and also the exponent like this.
int exp;
long val;
x = val e-exp;
is't probably a stupid question but im stuck in it
Don't have my arduino etc set up here at the moment, but the function you want to check out is pow().
Demo C program:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
int main(int argc, char *argv[])
    int number = 4855;
    int exponent = 2;
    float result;
    result = number * pow(10, -exponent);
    printf("Result: %f\n", result);
    return EXIT_SUCCESS;
I have assumed from your comment you want to change the sign on the exponent, hence the unary "-" in front of the exponent. Beware rounding errors - on my PC this converted 4855 to 48.54999.
You may want to look at "pow": POW - power function.
Udo
Tanks for you answer :slight_smile:
Paul J the demo program was just what i needed :slight_smile: and yes you are right about the 48.54999.
x = RegValue * pow(10, -RegExp);
Jesper
Yes now on the arduino if if the value is 4913 and the exponent i 3 i got 4.91 but it shut be 4.913 :~...
But if i have 2234 and exponent 2 the result is 22.34 and that is right.
I believe the default is to output to 2 decimal places - append a comma and a number indicating the number of decimal places?
Also, it looks like you are using the routine to move the decimal point, so pow() is probably over the top.
Here is a simpler demo program (again aimed at PC - I still don't have my arduino to hand!):
#include <stdio.h>
#include <stdlib.h>
    double number = 4855;
    double exponent = 2;
    int i;
    for (i=0; i < exponent; i++)
        number = number / 10;
    printf("Result: %f\n", number);
If you are also moving the decimal point in the other direction, then you will need to multiply rather than divide by 10.
