I'm trying to wrap my head around how to extract an array from a JSON element. In the case of the below JSON, I'm trying to access the "values" key.
{"act":"D8755ABF713C","id":4,"typ":4,"tank":2,"ip":"192.168.249.99","values":[0,1]}
Anyone have a clear way of accessing these elements? I've followed the deserialization tutorial for ArduinoJson6, but got lost in the process.
guix
2
I followed this tutorial and it won't compile. I'm using the ArduinoJson6 library and that might be part of the issue.
After you deserialize into 'doc', doc["values"][0] would get you the first (0) and doc["values"][1] would get you the second (1).
See the ArduinoJson Assistant:
Tell it you want to deserialize and paste in your JSON. It will write some code for you:
// const char* input;
// size_t inputLength; (optional)
StaticJsonDocument<192> doc;
DeserializationError error = deserializeJson(doc, input, inputLength);
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.f_str());
return;
const char* act = doc["act"]; // "D8755ABF713C"
int id = doc["id"]; // 4
int typ = doc["typ"]; // 4
int tank = doc["tank"]; // 2
const char* ip = doc["ip"]; // "192.168.249.99"
int values_0 = doc["values"][0]; // 0
int values_1 = doc["values"][1]; // 1
If you want the data in an array, you can replace that last bit with:
int values[2];
values[0] = doc["values"][0]; // 0
values[1] = doc["values"][1]; // 1
For larger arrays:
int values[N];
for (size_t i=0; i < N; i++)
values[i] = doc["values"][i];
This would fine if the number of values was fixed. Sometimes it is 1. Sometimes 4.
Figured it out.
JSonArray values=inbound['values'];
and then roll through it with
for(int i=0;i<values.size();i++) {
// Access elements here....
Perhaps you would have gotten better results if you had mentioned in your post that the the size of "values" varied.
size_t N = inbound["values"].size();
int values[N];
values[i] = inbound["values"][i];
