Eye Movement Controlled Car
I'm trying to make an arduino car project controlled by eye movements. I have a code in python that detects where the eye is looking, and according to this code, I want to send data to the arduino and activate the car. I am using Arduino uno, HC 06 Bluetooth module, L298N motor driver and 2 dc motors for the car. When I make all the connections and run the Python code, the leds of the arduino are on but the motors don't work. The arduino code and the part of the python code that sends data to the arduino is as follows. What could be the problem?
L298N motor driver https://lastminuteengineers.com/l298n-dc-stepper-driver-arduino-tutorial/
#include<SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);  // Communication RX,TX pins are determined.
// motor driver L298 pins named
const int in1=11;
const int in2=10;
const int in3=9;
const int in4=8;
  pinMode(in1,OUTPUT);
  pinMode(in2,OUTPUT);
  pinMode(in3,OUTPUT);
  pinMode(in4,OUTPUT);
  int sayac1=0, sayac2=0, i=0;  //variables that are not wanted to be reset in the loop
Defined as 0 outside the loop.
  int dizi[20];  // Created array to store the blinking data
  int gd=0;  //The variable "gd" is defined for the eye state (right, left, straight).
  int gk=0;  //The "gk" variable is defined for the blink status.
    int sh;  //The "sh" variable is defined for the data coming via serial communication.
    if(Serial.available())
      sh=Serial.read();
      if(sh<52)  // If the value of sh is less than 52, it is written to the gd variable.
      gd=sh;
      else if(sh==52)  // If the value of sh is 52, it is written to the gk variable.
      gk=sh;
     sayac1=sayac1+1;   //Increased counter1 by 1 for blink status
      if(sayac1==16)  // if the counter1 is 16, it is reset. (For about 2 seconds)
      sayac1=0;
      dizi[i]=sayac1;  //counter1 values transferred to array
      if(i>0)    //i>0 is checked because array[-1] problem will occur in case of i=0.
      if(dizi[i]==dizi[i-1])   //counter1 and i are reset if the same value occurs during two loops
      sayac1=0;
      i=0;
i++;  //dizi için i değişkeni 1 arttırıldı.
  if(sayac1==15)  // If counter1 is 15 (about 2sec), counter2 is increased by 1.
 sayac2=sayac2+1;
// All variables are written to the serial communication screen to control
    Serial.print("Goz Durumu:");
    Serial.println(gd);
    Serial.print("Goz Kırpma");
    Serial.println(gk);
    Serial.print("sayac1:");
    Serial.println(sayac1);
    Serial.print("sayac2:");
    Serial.println(sayac2);
    else   // If there is no data waiting to be read in the memory, the system is disabled. (Camera off or rpi off status)
    dur();
      if(sayac2==2) //counter2 resets to 2 so that it only takes 0 and 1 value.
   sayac2=0;
      if(sayac2==0)  // If counter2 is 0, the system is disabled.
  { dur();
  else if(sayac2==1)  // if counter2 is 1, the vehicle is activated
    if(gd==49)  // If gd 49, the left function is called.
    sol();
  else if(gd==51)  // If gd 49, the right function is called.
    sag();
  else if(gd==50)  // if gd is 50 the forward function is called
    duz();
// Stop, straight, right and left functions have been created according to L298n pins
   void dur()
    digitalWrite(in1,LOW);
    digitalWrite(in2,LOW);
    digitalWrite(in3,LOW);
    digitalWrite(in4,LOW);
   void duz()
    digitalWrite(in2,HIGH);
    digitalWrite(in3,HIGH);
   void sag()
   { digitalWrite(in1,LOW);
    digitalWrite(in4,HIGH);
   void sol()
     digitalWrite(in1,HIGH);
	if right_eye_ratio> 4.9 or left_eye_ratio> 4.9:
			cv2.putText(frame, "BLINKING", (50,150),font,4,(255,0,0 ))
			serial.write('4'.encode('utf-8'))
		else:
				if gaze_ratio <= 0.6:
					cv2.putText(frame, "LEFT", (0,100), font,2,(0,0,255),3)
					#Serial.write(49);
					serial.write('1'.encode('utf-8'))
				elif 0.6 < gaze_ratio < 1.5:
					cv2.putText(frame, "FORWARD", (100, 100), font, 2, (0, 0, 255), 3)
					#Serial.write (50);
					serial.write('2'.encode('utf-8'))
				elif gaze_ratio > 1.5:
					cv2.putText (frame, "RIGHT", (200, 100), font, 2, (0, 0, 255), 3)
					#Serial.write (51);
					serial.write('3'.encode('utf-8'))
Screenshot_2
is it not receiving characters correctly or is the motor not moving?
if those routines are just controlling the motor direction, do you need to set the enable pin HIGH?
I think it is behind the schematic you need to post, not a frizzy picture showing all connections including power and ground. Also post links to technical information on all the hardware devices, azon links are generally just sales info.
I'm new to arduino so i'm not exactly sure what the problem is. When I make all the connections and run the Python code, the leds of the arduino are on but dc motors don't work. I didn't set the enable pin thought, gonna try that.
add commands you can enter thru the serial interface to drive the motor. get that working, then test the other commands
Is your L298 a bare chip or a chip on a module? The modules I've seen (there are different ones from different manufacturers) allow you to make the enable pins high with a jumper. In fact the jumper's often in place, out the box.
You should, for completeness sake, provide details (make, model, url) of the module if you are indeed using one.
Do your serial prints indicate to you that the commands are arriving successfully at the Arduino?
It's a chip on a module, since the enable pins are for controlling the speed of the motor, I did not use them. but what I did is wrong it seems? As for the commands arriving successfully at the Arduino Arduino's led's are flashing when python code detects eye movements but I don't know how can check it another way.
Well they're actually for enabling the motors, which means the need to be high for full speed or pwm'd for variable speed.
You can jumper them from the pins just behind:
What are these for:
edit: sorry, I missed the pic before hence my unnecessary question about the chip and module
Arduino's led's are flashing is a wayyyy to unprecise description of what is happening.
This could be the LEDs of the serial interface which only indicates serial data send / receive
but nothing else than that.
How do you want to proceed?
unhappy way: trying all kinds of guessings what it might be.
the needs work way:
writing a testcode that does nothing more than switch one motor on / off
next step
writing a testcode that does nothing more than switch both motors on / off
next step
writing a testcode that does nothing more than receive one command from python print the command to the serial monitor
next step
writing a testcode that does nothing more than receive one command sended from the serial monitor and then echo this command (=print) the command to the serial monitor
etc. etc.
best regards Stefan
