OK you asked for it GRIN
This is an example for our Monochrome OLEDs based on SSD1306 drivers
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/category/63_98
This example is for a 128x64 pixel display using I2C to communicate
3 pins are required to interface (two I2C and one reset).
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source
hardware by purchasing products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries,
with contributions from the open source community.
BSD license, check license.txt for more information
All text above, and the splash screen below must be
included in any redistribution.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "Adafruit_VEML6075.h"
#include <ezButton.h>
Adafruit_VEML6075 uv = Adafruit_VEML6075();
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
ezButton button1(2); // create ezButton object that attach to pin 2;
ezButton button2(3); // create ezButton object that attach to pin 3;
ezButton button3(4); // create ezButton object that attach to pin 4;
ezButton button4(5); // create ezButton object that attach to pin 5;
ezButton button5(6); // create ezButton object that attach to pin 6;
float dose_div;
button1.setDebounceTime(50); // set debounce time to 50 milliseconds
button2.setDebounceTime(50); // set debounce time to 50 milliseconds
button3.setDebounceTime(50); // set debounce time to 50 milliseconds
button4.setDebounceTime(50); // set debounce time to 50 milliseconds
button5.setDebounceTime(50); // set debounce time to 50 milliseconds
Serial.println("VEML6075 Full Test");
if (! uv.begin()) {
Serial.println("Failed to communicate with VEML6075 sensor, check wiring?");
Serial.println("Found VEML6075 sensor");
// Set the integration constant
uv.setIntegrationTime(VEML6075_100MS);dose_div=10;
// Get the integration constant and print it!
Serial.print("Integration time set to ");
switch (uv.getIntegrationTime()) {
case VEML6075_50MS: Serial.print("50"); break;
case VEML6075_100MS: Serial.print("100"); break;
case VEML6075_200MS: Serial.print("200"); break;
case VEML6075_400MS: Serial.print("400"); break;
case VEML6075_800MS: Serial.print("800"); break;
Serial.println("ms");
// Set the high dynamic mode
uv.setHighDynamic(true);
// Get the mode
if (uv.getHighDynamic()) {
Serial.println("High dynamic reading mode");
Serial.println("Normal dynamic reading mode");
// Set the mode
uv.setForcedMode(false);
// Get the mode
if (uv.getForcedMode()) {
Serial.println("Forced reading mode");
Serial.println("Continuous reading mode");
// Set the calibration coefficients
uv.setCoefficients(0, 0, // UVA_A and UVA_B coefficients
0, 0, // UVB_C and UVB_D coefficients
0, 0); // UVA and UVB responses
//SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display.clearDisplay();
// display.display() is NOT necessary after every single drawing command,
// unless that's what you want...rather, you can batch up a bunch of
// drawing operations and then update the screen all at once by calling
// display.display(). These examples demonstrate both approaches...
//testdrawline(); // Draw many lines
// testdrawrect(); // Draw rectangles (outlines)
// testdrawchar(); // Draw characters of the default font
display.setTextSize(3); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0, 0); // Start at top-left corner
display.cp437(true); // Use full 256 char 'Code Page 437' font
// Not all the characters will fit on the display. This is normal.
// Library will draw what it can and the rest will be clipped.
float UVA_Dose;
float UVB_Dose;
float INDEX;
float UVA_mW;
float UVB_mW;
button1.loop(); // MUST call the loop() function first
button2.loop(); // MUST call the loop() function first
button3.loop(); // MUST call the loop() function first
button4.loop(); // MUST call the loop() function first
button5.loop(); // MUST call the loop() function first
int btn1State = button1.getState();
int btn2State = button2.getState();
int btn3State = button3.getState();
int btn4State = button4.getState();
int btn5State = button5.getState();
if(button1.isPressed())
Serial.println("The button 1 is pressed");
if(button1.isReleased()){
Serial.println("The button 1 is released");
// Code to initialise display for reading uv goes here
if(button2.isPressed())
Serial.println("The button 2 is pressed");
if(button2.isReleased()){
Serial.println("The button 2 is released");
// Code to initialise display for dose reading goes here
if(button3.isPressed())
Serial.println("The button 3 is pressed");
if(button3.isReleased())
Serial.println("The button 3 is released");
if(button4.isPressed())
Serial.println("The button 4 is pressed");
if(button4.isReleased())
Serial.println("The button 4 is released");
if(button5.isPressed())
Serial.println("The button 5 is pressed");
if(button5.isReleased())
Serial.println("The button 5 is released");
Serial.print("Raw UVA reading: "); Serial.println(String(uv.readUVA()));
Serial.print("Raw UVB reading: "); Serial.println(String(uv.readUVB()));
Serial.print("UV Index reading: "); Serial.println(String(uv.readUVI()));
UVA_mW =((uv.readUVA())/1000);
UVB_mW =((uv.readUVB())/1000);
INDEX =((uv.readUVI()));
if (UVA_mW>0.1) {
UVA_Dose = UVA_Dose + UVA_mW/dose_div;//convert to millijoules
displayreading(UVA_mW,UVB_mW,INDEX);
//delay(1000);
//displaydose(UVA_Dose,UVB_Dose,'B');
//Serial.print("UVA Dose: ");Serial.println(UVA_Dose);
//Serial.print("UVB Dose: ");Serial.println(UVB_Dose);
void displayreading(float UVA_mW,float UVB_mW,float INDEX) // Value is expected to be in mW per cm squared
char x;
char y;
char z;
char w;
char charBuf[8];
String stringOne = (String((UVA_mW)));
stringOne.toCharArray(charBuf,8);
w=stringOne[0];
x=stringOne[1];
y=stringOne[2];
z=stringOne[3];
display.setTextSize(2) ;
display.setCursor(78,6);
display.write(w);
display.setCursor(90,6);
display.write(x);
display.write(y);
display.setCursor(114,6);
display.write(z);
stringOne = (String((UVB_mW)));
w=stringOne[0];
x=stringOne[1];
y=stringOne[2];
z=stringOne[3];
display.setCursor(78,32);
display.write(w);
display.setCursor(90,32);
display.write(x);
display.write(y);
display.setCursor(114,32);
display.write(z);
display.setTextSize(1);
display.setCursor(80, 50);
display.write('m');
display.setCursor(88,50);
display.write('W');
display.setCursor(96, 50);
display.write('/');
display.setCursor(104, 50);
display.write('c');
display.setCursor(112,50);
display.write('m');
display.setCursor(120, 50);
display.write('2');
display.setCursor(80, 23);
display.write('m');
display.setCursor(88 ,23);
display.write('W');
display.setCursor(96, 23);
display.write('/');
display.setCursor(104,23);
display.write('c');
display.setCursor(112,23);
display.write('m');
display.setCursor(120, 23);
display.write('2');
display.display();
void displaydose(float UVA_Dose,float UVB_Dose,char uv) //Dose is expected to be in millijoules
char v;
char w;
char x;
char y;
char z;
char charBuf[8];
String stringOne = (String(UVA_Dose));
v=stringOne[0];
w=stringOne[1];
x=stringOne[2];
y=stringOne[3];
z=stringOne[4];
display.setTextSize(3) ;
display.setCursor(6,32);
display.write(v);
display.setCursor(26,32);
display.write(w);
display.setCursor(46,32);
display.write(x);
display.setCursor(66,32);
display.write(y);
display.setCursor(86,32);
display.write(z);
display.display();
void init_displaydose();{display.clearDisplay();
display.drawRect(0, 0, display.width(), display.height(), SSD1306_WHITE);
display.setCursor(5, 6);
display.write('U');
display.setCursor(20, 6);
display.write('V');
display.setCursor(35, 6);
display.write('A');
display.setCursor(50,6);
display.write(' ');
display.setCursor(65, 6);
display.write('D');
display.setCursor(80, 6);
display.write('O');
display.display();
display.setCursor(95, 6);
display.write('S');
display.display();
display.setCursor(110, 6);
display.write('E');
void init_displayreading(void);{
//display.fillRect(64, 1,64,25, SSD1306_BLACK);
display.write('U');
display.setCursor(25, 6);
display.write('V');
display.setCursor(46, 6);
display.write('A');
display.setCursor(5, 34);
display.write('U');
display.setCursor(25, 34);
display.write('V');
display.setCursor(46, 34);
display.write('B');
display.display();
