system
1
Sorry for opening a new thread. I think in my old thread my problem description was a bit confusing.
I have two LEDs and want to fade them out. But want the 2nd LED to start fading out when the first is about half way faded out.
I really don't know how to do this.
Any help please..........
Look in the tutorials for the "blink without delay" example, and "fade", instead of "blink".
system
3
I know how to fade them, but not how to start fading the 2nd one while the first one is still fading.
system
4
Maybe you can post some code you're using to fade one LED.
That way we can help you fade the second one in the most similar method.
system
5
#define NUMLEDS 2
#define BUTTON 13
int val = 0;
int oldVal = 0;
int state = 0;
int led[NUMLEDS]={11,10};
void setup(){
for(int i = 0; i<NUMLEDS; i++){
pinMode(led*,OUTPUT);*
- pinMode(BUTTON,INPUT);*
- Serial.begin(9600);*
void loop(){
- val = digitalRead(BUTTON);*
- Serial.println(val);*
- if((val==HIGH)&&(oldVal==LOW)){*
- state=1-state;*
- delay(10);*
- oldVal=val;*
- if(state==1){*
- for(int i = 0; i<NUMLEDS; i++){*
_ digitalWrite(led*,HIGH);*_
* delay(3000);*
_ for(int i = 2*255; i>=0; i--){_
* fading1(i);*
* //Serial.println(i);*
* state=0;*
* else{*
* for(int i = 0; i<6; i++){*
_ digitalWrite(led*,LOW);
void fading1(int i){_
* int value1 = i-255;*
* int value2 = i;*
* analogWrite(led[0],value1);*
* Serial.println(value1);*
* if (value1 < 128){*
* analogWrite(led[1],value2);*
* if (value1<1){*
* value1=0;*
* delay(10);*
for (int light = 255; light <=0; --light) {
analogWrite (LED1_PIN, light);
if (light < 128) {
analogWrite (LED2_PIN, light * 2);
delay (100);
system
7
thanks.
now the 2nd LED starts fading when the 1st LED reaches 128 but unfortunately they reach 0 at the same time.
When the 1st LED is at 0 I want the 2nd to be at 128 fading down to 0.
system
8
I've copied the essential parts of your code and used it as a base for this code that seems to do what you requested.
int led[]={5,6};
pinMode(led[0], OUTPUT);
pinMode(led[1], OUTPUT);
for(int i=255 + 127; i>=0; i--) {
fading1(i);
void fading1(int i) {
int value1 = min(255, max(0, i));
int value2 = min(255, max(0, i - 127));
analogWrite(led[0], value1);
analogWrite(led[1], value2);
Serial.println(value2);
delay(10);
P.S. if you put your code between [ code ] and [ /code ] it's easier read
system
9
hey thank you so much. that did it.
min() and max() just wonderful.
system
10
Just be aware when using min/max that it might seem reversed in some cases.
This one is straight forward:
int c = max(a, b); // c becomes the greater of a and b
But in this case, it's a bit odd:
int c = min(255, a); // c becomes a, with a maximum of 255
int d = max(0, b); // d becomes b, with a minimum of 0
