After trying to alter the code in the first post,I switched to the code I used first.
I think this code might be better. As HazardsMind pointed out to me the code from the first post has a lot of delays.
The code i have now has 1 or 2 delays,it uses the internal pullup resistor and it has the fade off I want.
Credit goes to xl97 from the RPF Forum
Here's the sketch:
// IronMan Helmet: eye blink sequence_v1.0
// created by: xl97
//import servo lib
#include <Servo.h>
//servo object names
Servo myservo; // create servo object to control a servo
Servo myservo1;
const int buttonPin = 2; // the pin that the pushbutton is attached to
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// led control pins (need to be PWM enabled pins for fading)
const int leftEye = 6; // the number of the left eye/pcb LEDs
const int rightEye = 3; // the number of the right eye/pcb LEDs
unsigned long fadeDelay = .5; //speed of the eye 'fade'
unsigned long callDelay = 700; //length to wait to start eye flicker after face plate comes down
unsigned long blinkSpeed = 100; //delay between init blink on/off
unsigned long currentPWM = 0;
boolean isOpen = true;
#define S_IDLE 1
#define S_LEDON 2
#define S_WAITON 3
#define S_LEDOFF 4
#define S_WAITOFF 5
#define S_INITON 6
#define S_INITWAIT 7
#define S_BLINKON 8
#define S_SERVOUP 9
#define S_SERVODOWN 0
#define S_SERVOWAIT 10
//FSM init vars
static int state = S_IDLE; // initial state is 1, the "idle" state.
static unsigned long lastTime; // To store the "current" time in for delays.
// Set up serial port
//start it off
//state = S_BLINKON;
Serial.print("INTIT STATE: ");
Serial.println(state);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo1.attach(10); // attaches the servo on pin 10 to the servo object
pinMode(buttonPin, INPUT); // initialize the button pin as a input
digitalWrite(buttonPin, HIGH); //use interal pull up resistors
switch(state)
case S_IDLE:
// We don't need to do anything here, waiting for a forced state change...like button press.
//check mian button state
buttonState = digitalRead(buttonPin);
// compare buttonState to previous state
if (buttonState != lastButtonState) {
//if button pressed/down
if (buttonState == LOW){
//ie: pressed
if(isOpen == true){
Serial.print("CLOSING FACE PLATE: ");
Serial.println(isOpen, DEC);
state = S_SERVODOWN;
else{
Serial.print("OPENING FACE PLATE: ");
//state = S_SERVOUP;
state = S_LEDOFF;
isOpen = !isOpen;
else{
//went from ON/HIGH to LOW/OFF..ie: released
//Serial.print("RELEASE: ");
//Serial.println(isOpen, DEC);
// save the current state for next loop
lastButtonState = buttonState;
case S_BLINKON:
Serial.println("init blink.........");
//do blink routine here
//one blink
analogWrite(leftEye, 155);
analogWrite(rightEye, 155);
delay(blinkSpeed);
analogWrite(leftEye, 0);
analogWrite(rightEye, 0);
delay(10);
//two blinks
delay(blinkSpeed);
delay(10);
state = S_LEDON;
case S_LEDON:
Serial.println("increase........");
lastTime = millis(); // Remember the current time
analogWrite(leftEye, currentPWM);
analogWrite(rightEye, currentPWM);
state = S_WAITON; // Move to the next state
case S_WAITON:
// If one second has passed, then move on to the next state.
if(millis() > (lastTime + fadeDelay)){
if(currentPWM < 255){
currentPWM += 5;
state = S_LEDON;
else{
Serial.println("@ 255 done........");
state = S_IDLE;
//state = S_LEDOFF; //no auto turn off.. set to idle state
case S_LEDOFF:
Serial.println("........decrease");
state = S_WAITOFF;
case S_WAITOFF:
if(currentPWM > 0){ //change 0 to higher number to init face 'up' function sooner.
currentPWM -= 5;
state = S_LEDOFF;
else{
Serial.println("@ 0 done........");
state = S_SERVOUP; //leds off..raise faceplate
case S_SERVOUP:
Serial.println("servo up.........");
myservo.write(20);
myservo1.write(20);
state = S_IDLE;
case S_SERVODOWN:
Serial.println("servo down.........");
myservo.write(100);
myservo1.write(100);
state = S_SERVOWAIT;
case S_SERVOWAIT:
// If enough time has passed, call the eye flicker routine
if(millis() > (lastTime + callDelay)){
Serial.println("start eye flicker routine");
state = S_BLINKON;
else{
Serial.println("waiting........");
default:
state = S_IDLE;
This code works great except it does not run the servo's in mirror.
So i changed:
case S_SERVOUP:
myservo.write(20);
myservo1.write(20);
state = S_IDLE;
case S_SERVODOWN:
myservo.write(100);
to
case S_SERVOUP:
myservo.write(20);
state = S_IDLE;
case S_SERVODOWN:
myservo.write(100);
myservo1.write(20);
Now when I disconnect the battery pack and reconnect it ,1 of the servo's turns to a starting point.
I guess the code does tell it exactly what it supposed to do.
My question is where or how can I alter the code the have the servo's start at the same point.
Thank you.
