I am trying to submit data to an ic2cloud server, using test code,.. However, my efforts are failing with various errors.
Requesting URL: GET http://www.ic2pro.com:80/Wire/connector/set?id=111-222-444&TEMPERATURE=26.56 HTTP/1.1
Running option1
HTTP/1.1 400 Bad Request
Server: awselb/2.0
Date: Sun, 14 Oct 2018 16:35:13 GMT
Content-Type: text/html
Content-Length: 138
Connection: close
Running option2
HTTP/1.1 502 Bad Gateway
Server: awselb/2.0
Date: Sun, 14 Oct 2018 16:45:01 GMT
Content-Length: 138
Connection: close
<html>
<head><title>502 Bad Gateway</title></head>
<body bgcolor="white">
<center><h1>502 Bad Gateway</h1></center>
</body>
</html>
Running option3
Server: awselb/2.0
Date: Sun, 14 Oct 2018 16:42:37 GMT
Content-Length: 138
Connection: close
<html>
<head><title>400 Bad Request</title></head>
<center><h1>400 Bad Request</h1></center>
</body>
</html>
Running option4
Server: awselb/2.0
Date: Sun, 14 Oct 2018 16:50:35 GMT
Content-Length: 138
Connection: close
<html>
</body>
</html>
and my source program is as follows:-
#include <ESP8266WiFi.h>
#include <OneWire.h>
OneWire ds(D5);
const char* ssid = "NULL"; // wifi ssid
const char* password = "NULL"; // wifi password
String auth = "bWFyBoYW1ibGlu1lLnVrOjEyMzQ1Njc4"; // Authentication credentials Create a string from <email_address>:<API_Password> and encode it base64
// The sample:
// String auth = "dXNlcjpwYXNzd29yZA=="
// is the encoding for "user:password"
int indx = 0;
#define SizeInputString 64
char WebInputString[SizeInputString];
const char* host = "www.ic2pro.com";
const int httpPort = 80;
String devId = "111-222-444"; // Device ID. CREATE YOUR OWN GUID; Use this http://www.guidgenerator.com/
String getTemperature()
byte type_s;
byte data[12];
byte addr[8];
float celsius;
String scelsius;
if ( !ds.search(addr)) { // find chip
ds.reset_search();
delay(250);
return "ERR1";
if (OneWire::crc8(addr, 7) != addr[7]) { // check CRC
return "ERR2";
switch (addr[0]) { // test if it's a proper chip
case 0x10: type_s = 1; break;
case 0x28: type_s = 0; break;
case 0x22: type_s = 0; break;
default:
Serial.println("Device is not a DS18x20 family device."); // Not a proper chip
return "ERR3";
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // initiate conversion
delay(1000); // maybe 750ms is enough, maybe not
ds.reset();
ds.select(addr);
ds.write(0xBE);
for (byte i = 0; i < 9; i++) { // read data
data[i] = ds.read();
int16_t raw = (data[1] << 8) | data[0]; // Convert the data to temperature
if (type_s) {
raw = raw << 3;
if (data[7] == 0x10) {
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw & ~7; // based on the resolution make the conversion
else if (cfg == 0x20) raw = raw & ~3;
else if (cfg == 0x40) raw = raw & ~1;
celsius = (float)raw / 16.0;
scelsius = String(celsius);
return scelsius;
void sendTemperature() {
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return;
// We now create a URI for the request
String url = "/Wire/connector/set?id=" + devId + "&TEMPERATURE=" + getTemperature();
Serial.print("Requesting URL: ");
// Serial.println(url);
Serial.println("GET http://" + String(host) + ":" + String(httpPort) + "/Wire/connector/set?id=" + devId + "&TEMPERATURE=" + getTemperature() + " HTTP/1.1"); // submit HTTP request
// This will determine how data is sent to the server
#define option4 true
#ifdef option1
Serial.println("Running option1");
client.print("GET http://" + String(host) + ":" + String(httpPort) + "/Wire/connector/set?id=" + devId + "&TEMPERATURE=" + getTemperature() + " HTTP/1.1"); // submit HTTP request
client.print(String("Authorization: Basic " + auth + "\r\n" +
"Connection: close\r\n\r\n"));
#elif option2
Serial.println("Running option2");
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
#elif option3
Serial.println("Running option3");
client.print(String("GET http://" + String(host) + ":" + String(httpPort) + "/Wire/connector/set?id=" + devId + "&TEMPERATURE=" + getTemperature() + " HTTP/1.1")); // submit HTTP request
#elif option4
Serial.println("Running option4");
#endif
// Read all the lines of the reply from server and print them to Serial
indx = 0;
unsigned long waitStart = millis(); // Initialise start time for Reading
unsigned long tooLong = 5000UL; // Don't wait more than 5 seconds for all data
while (client.connected() && millis() - waitStart < tooLong) {
while (client.available() > 0) {
char c = client.read();
WebInputString[indx] = c;
indx++;
// Check if input stream will overflow buffer
if ( indx > (SizeInputString - 1) ) {
Serial.println("Input string Too Big");
//client.readStringUntil('>').
if ( c == '\r' || c == '\n' ) {
// The end of the line or New Line arrived.
WebInputString[indx - 1 ] = '\0';
indx = 0;
Serial.println(WebInputString);
// splitCommand();
} // while client available
} // while client connected
Serial.println("closing connection");
Serial.begin(57200);
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
sendTemperature();
delay(3000);
I have tried more variants than I care/can list but none successfully submit data to the cloud,. is anyone able to spread some light on the error of my ways,...
Are there any things I can change to improve the error reporting,.. as I am at a loss..
Many tx
