Fall detection using MPU6050 and sim900a
I am trying to make fall detection using MPU6050, SIM900a, and Arduino Nano. after uploading the code to Arduino, the serial monitor show me this: serial monitor output
this is the code that I have tried,
[code] ```
#include <SoftwareSerial.h> // Library for using software serial communication
//______________________sms part_____________________________________________
SoftwareSerial SIM900(7, 8); // rx, tx
char c = ' '; // variable to store the data from the sms module
//_______________________MPU part_______________________________________________________
#include <Wire.h>
const int MPU_addr=0x68;  // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
float ax=0, ay=0, az=0, gx=0, gy=0, gz=0;
//int data[STORE_SIZE][5]; //array for saving past data
//byte currentIndex=0; //stores current data array index (0-255)
boolean fall = false; //stores if a fall has occurred
boolean trigger1=false; //stores if first trigger (lower threshold) has occurred
boolean trigger2=false; //stores if second trigger (upper threshold) has occurred
boolean trigger3=false; //stores if third trigger (orientation change) has occurred
byte trigger1count=0; //stores the counts past since trigger 1 was set true
byte trigger2count=0; //stores the counts past since trigger 2 was set true
byte trigger3count=0; //stores the counts past since trigger 3 was set true
int angleChange=0;
void setup(){
  randomSeed(analogRead(0));
  Serial.begin(9600);// baudrate for serial monitor
    while (!Serial) {
    ; // wait for serial port to connect. Needed for Native USB only
  SIM900.begin(9600); // baudrate for GSM shield
  Serial.println(" Logging time completed!");
  delay(1000); // wait for 5 seconds
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
void loop(){
//______________________________________MPU_________________________________________
  mpu_read();
  //2050, 77, 1947 are values for calibration of accelerometer
  // values may be different for you
  ax = (AcX-2050)/16384.00;
  ay = (AcY-77)/16384.00;
  az = (AcZ-1947)/16384.00;
  //270, 351, 136 for gyroscope
  gx = (GyX+270)/131.07;
  gy = (GyY-351)/131.07;
  gz = (GyZ+136)/131.07;
  // calculating Amplitute vactor for 3 axis
  float Raw_AM = pow(pow(ax,2)+pow(ay,2)+pow(az,2),0.5);
  int AM = Raw_AM * 10;  // as values are within 0 to 1, I multiplied
                         // it by for using if else conditions
 Serial.println(AM);
 //Serial.println(PM);
 //delay(500);
   if (trigger3==true){
     trigger3count++;
     //Serial.println(trigger3count);
     if (trigger3count>=10){
        angleChange = pow(pow(gx,2)+pow(gy,2)+pow(gz,2),0.5);
        //delay(10);
        Serial.println(angleChange);
        if ((angleChange>=0) && (angleChange<=10)){ //if orientation changes remains between 0-10 degrees
            fall=true; trigger3=false; trigger3count=0;
        else{ //user regained normal orientation
           Serial.println("TRIGGER 3 DEACTIVATED");
  if (fall==true){ //in event of a fall detection
    Serial.println("FALL DETECTED");
    MakeCall;
    delay(100000);
    fall=false;
   // exit(1);
  if (trigger2count>=6){ //allow 0.5s for orientation change
    trigger2=false; trigger2count=0;
    Serial.println("TRIGGER 2 DECACTIVATED");
  if (trigger1count>=6){ //allow 0.5s for AM to break upper threshold
    trigger1=false; trigger1count=0;
    Serial.println("TRIGGER 1 DECACTIVATED");
  if (trigger2==true){
    trigger2count++;
    //angleChange=acos(((double)x*(double)bx+(double)y*(double)by+(double)z*(double)bz)/(double)AM/(double)BM);
    angleChange = pow(pow(gx,2)+pow(gy,2)+pow(gz,2),0.5); Serial.println(angleChange);
    if (angleChange>=30 && angleChange<=400){ //if orientation changes by between 80-100 degrees
      trigger3=true; trigger2=false; trigger2count=0;
      Serial.println("TRIGGER 3 ACTIVATED");
  if (trigger1==true){
    trigger1count++;
    if (AM>=12){ //if AM breaks upper threshold (3g)
      trigger2=true;
      Serial.println("TRIGGER 2 ACTIVATED");
  if (AM<=2 && trigger2==false){ //if AM breaks lower threshold (0.4g)
    trigger1=true;
    Serial.println("TRIGGER 1 ACTIVATED");
//It appears that delay is needed in order not to clog the port
  delay(100);
//______________________________MPU raeding________________________
void mpu_read(){
  Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr,14,true);  // request a total of 14 registers
  AcX=Wire.read()<<8|Wire.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  AcY=Wire.read()<<8|Wire.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  AcZ=Wire.read()<<8|Wire.read();  // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  Tmp=Wire.read()<<8|Wire.read();  // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
  GyX=Wire.read()<<8|Wire.read();  // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  GyY=Wire.read()<<8|Wire.read();  // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  GyZ=Wire.read()<<8|Wire.read();  // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
//______________________________________GSM module calling function________________
void MakeCall()
   SIM900.println("ATD+*********;"); // ATDxxxxxxxxxx; -- watch out here for semicolon at the end!!
  Serial.println("Calling  "); // print response over serial port
  delay(20000); //wait
the configuration of MPU050
VCC --- 5V in arduino
GND ----GND
SCL ----A5
SDA----A4
INT ----- D2
The serial monitor should show some numbers first but instead of showing numbers trigger 1 activated and disactivate automatically and I didn't even touch it . No matter how much I throw the MPU6050, trigger 2 and 3 are not activated. all the three trigger must be activated to make the sim900a module make a call.
what could be the reason ? could be the code or the hardware connection. here is a picture of the MPU position in case it could be the problem.
https://i.stack.imgur.com/z9cd5.jpg
hii.I want to ask if you get the solution?
Better to PM them. It's unlikely that they will see this, it's from April
