Fast LED Library Red and Green swapped?
Hello Everybody,
Anyone noticed that in the fast LED library the Red and Green are swapped?
Like that:
leds[i] = CRGB::Red; // is green
and
leds[i] = CRGB::Green; // is red
Mark
It is your LED strip, some have them swapped. Just compensate by defining the correct mode in the code.
Does this mean there are two kind of WS2812B ?
What I should change in this small minimal example?
#include "FastLED.h"
#define NUM_LEDS 5
#define DATA_PIN 10
// Define the array of leds
CRGB leds[NUM_LEDS];
  FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
  leds[0] = CRGB::Red; // shows green
  leds[1] = CRGB::Green; // shows red
  leds[2] = CRGB::Blue;
  FastLED.show();
  leds[0] = CRGB::Black;
  leds[1] = CRGB::Black;
  leds[2] = CRGB::Black;
  FastLED.show();
Yes. I have found the surface mount LEDs are RGB where as the individual packages, with wire ends are GRB.
Change CRGB to CGRB and RGB>to GRB and if that doesn’t work then read the documentation for the library.
Hello Mike,
thank you. I have found it. Only the line in the setup method needs to be changed.
Here is the code:
#define NUM_LEDS 5
#define DATA_PIN 10
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS); // for GRB LEDs
  //FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS); // for RGB LEDs
  FastLED.show();
  FastLED.show();
I have used only WS2812B SMD LEDs.
Mark
