fast mosfet as switch
Hello to all.
I need to a mosfet with below property:
Fsw=10KHZ
Vds=about 50 volts
Id=about 10Amps
Rds=about 5 mOhms
VGs=about 6 volts
And to be known.
Thanks.
Digikey has an excellent MosFet selection interactive table. I'm sure it can offer a number of possibilities.
STP130N8F7 should fit.
leoncorleone:
Hello to all.
Fsw=10KHZ
Vds=about 50 volts
Id=about 10Amps
Rds=about 5 mOhms
VGs=about 6 volts
And to be known.
Thanks.
p-channel or n-channel?
"to be known" means what exactly?
"about" means what exactly?
No MOSFET is slow they don't have a way to be slow. So long as the gate is driven
properly. How are you imagining the gate will be driven?
If the on-resistance is 5 milliohms or better, there's never a need to check the Id rating
is 10A or more, its likely to be much much higher (package limited usually)
