FastLED without delay()?
Hello all,
I'm trying to light my LED strip while running other stuff, unfortunately the example below uses the delay() function which is interrupting the motor movement.
#include <FastLED.h>
#define NUM_LEDS 6
#define DATA_PIN 5
CRGB leds[NUM_LEDS];
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
  for(int x = 0; x < NUM_LEDS; x++)
    leds[x].setRGB(255,69,0);
    FastLED.show();
    delay (50); //This is what I need to replace
    leds[x] = CRGB::Black;
I can't figure how to use millis() in my case:
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 1000;
const byte ledPin = 13;
  pinMode(ledPin, OUTPUT);
  startMillis = millis();
  currentMillis = millis();
  if (currentMillis - startMillis >= period)
    digitalWrite(ledPin, !digitalRead(ledPin));
    startMillis = currentMillis;
Any thoughts?
Thanks,
aminabudahab:
Your millis() code looks fine. What is the problem?
The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
You cannot use a "for" loop. You should use a global instance of "x", something like this:
int x = 0;
  if (currentMillis - startMillis >= period) {
    FastLED.show();
    if (++x >= NUM_LEDS) x = 0;
  //Other stuff here..
Danois90:
int x = 0;
    FastLED.show();
  //Other stuff here,,
That worked perfectly, been trying to wrap my head around it for 2 days now. I wouldn't have thought that I can't use for loops.
Thanks a lot :smiley:
Remember that FastLED replaces delay() with a busy wait...
