Fault on interrupt or bare metal(no OS) environment Error: Main stack(200075d0) was overflow
Hello to everyone , i use this code :
#include <Wire.h>
#include <RTClib.h>
#include <Arduino.h>
#include <MFRC522.h>
#include <WiFiS3.h>
#include <Firebase_ESP_Client.h>
// Provide the token generation process info.
#include "addons/TokenHelper.h"
// Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
#define SS_PIN 10
#define RST_PIN 9
// Replace these with your actual WiFi credentials
#define WIFI_SSID "ORIGINAL21" // Your WiFi SSID
#define WIFI_PASSWORD "..." // Your WiFi Password
#define DATABASE_URL "..."
#define API_KEY "...."
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
RTC_DS3231 rtc;
  Serial.begin(115200); // Ensure this matches the Serial Monitor baud rate
  // Initialize WiFi
  Serial.println("Connecting to WiFi...");
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
    Serial.print(".");
  Serial.println("\nWiFi connected");
  Serial.print("Connected with IP: ");
  // Firebase configuration
  Serial.println("Configuring Firebase...");
  config.api_key = API_KEY;
  config.database_url = DATABASE_URL;
  auth.user.email = "....";
  auth.user.password = "....";
  Firebase.begin(&config, &auth);
  Firebase.reconnectWiFi(true);
  Serial.println("Firebase initialized");
  // Initialize RTC
  Serial.println("Initializing RTC...");
  if (!rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (rtc.lostPower()) {
    Serial.println("RTC lost power, let's set the time!");
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  // Initialize SPI and MFRC522
  Serial.println("Initializing SPI and MFRC522...");
  SPI.begin();
  mfrc522.PCD_Init();
  Serial.println("Approximating your card to the reader...");
  if (!Firebase.ready()) {
    Serial.println("Firebase not ready, reconnecting...");
    Firebase.begin(&config, &auth); // Reinitialize Firebase
    return;
  // Check for RFID tag
  if (!mfrc522.PICC_IsNewCardPresent()) {
    return;
  if (!mfrc522.PICC_ReadCardSerial()) {
    return;
  Serial.println("RFID Tag detected!");
  // Show UID on serial monitor
  Serial.print("UID tag: ");
  char content[32] = {0};
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    char hexDigit[3];
    sprintf(hexDigit, "%02X", mfrc522.uid.uidByte[i]);
    strcat(content, hexDigit);
  Serial.println(content);
  // Get current time from RTC
  DateTime now = rtc.now();
  char currentTime[20];
  sprintf(currentTime, "%04d-%02d-%02d %02d:%02d:%02d", now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());
  Serial.println("Current Time: " + String(currentTime));
  // Prepare the path and the value to set in the database
  char path[64];
  char tagValue[128];
  sprintf(path, "/rfid_tags/%s", content); // Path in Firebase where the data will be stored
  sprintf(tagValue, "Tag read at: %s", currentTime);
  // Debug print to check if path and tagValue are correct
  Serial.println("Path: " + String(path));
  Serial.println("Tag Value: " + String(tagValue));
  // Send UID and a timestamp to Firebase Database
  Serial.println("Sending data to Firebase...");
  if (Firebase.RTDB.setString(&fbdo, path, tagValue)) {
    Serial.println("Stored RFID tag to Firebase successfully!");
    Serial.println("Failed to store data in Firebase!");
    Serial.println("Reason: " + fbdo.errorReason());
  // Halt PICC
  mfrc522.PICC_HaltA();
  delay(1000); // Add a delay to avoid flooding the serial output
and i have this error:Fault on interrupt or bare metal(no OS) environment
i use arduino uno R4 wifi board.It has esp32-S3 .
