Faulty ir reader, or bad code?
Im currently trying to make a gift for my gf, my 8x8 led display workds perfect, its the ir sensor I tried implementing to turn it off/off or to dim/brighten it that wont work. Is thisdue to my code or faulty hardware? Thanks in advance!
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <IRremote.h>
const int RECV_PIN = 7;
IRrecv IrReceiver(RECV_PIN);
decode_results results;
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4 // 4 blocks
#define CS_PIN 3
int Bright = 7;
int ON = 1;
MD_Parola ledMatrix = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
  IrReceiver.enableIRIn();
  IrReceiver.blink13(true);
  Serial.println(RECV_PIN);
  ledMatrix.begin();
  ledMatrix.setIntensity(Bright);
  ledMatrix.displayClear();
  ledMatrix.displayScroll("Sweet heartfell message", PA_CENTER, PA_SCROLL_LEFT, 80);
  if (ledMatrix.displayAnimate()) {
    ledMatrix.displayReset();
  if (IrReceiver.decode(&results) == 0xFFA25D) { //off
      Bright =0;
      ON == 2;
      IrReceiver.resume();
  if(IrReceiver.decode(&results) == 0xFFA25D && ON == 2){
      Bright =7;
      ON == 1;
 if (IrReceiver.decode(&results) == 0xF076C13B) { //down
      Bright =-1;
  if (IrReceiver.decode(&results) == 0xFF906F) { //up
      Bright =+1;
Test your hardware with an example program for your hardware. If it works there, then it is your code.
I think its hardware issues, sucks I guess.
��Ð����X`�ؘq0�iY�e��X�ZHZ�Y�J�i�=Y%�-�i��@��I�iAI�іa��H��єD��~�Q�Il���Q�Yhy�Z�ɠ�yL�(�Z0���@Q�Q�Q��Aj�	���z*$�X
����5�~�(�H�HHHHHHHHHHJJJJJJJJhؖ����@������tA=y�iiY��Y��KY��qk����ZֶAiz���Qa�H�Ii�jj�Q%�-�ij2�ܘ��0�A�<�Q�Z=A�YqXjY��$X��ֺ�c�qH�Q�Q�Q��h�Q���h�
��HŽ,Ԁ�������������,A�HIEa�aHA(�hؖa�<@|����tA9�y�IiY�eY��[�Z�qk������eԔIi���іa��H����a�H������8z[�Q�Yjy�ZA�<�Q��O!���>�J�@��@A�A�A���H	�h�aY��i�L(���H�<slX%JJB�����I�,�<�����<ɶX�YZ�X���������Ay
a��$VѴ�a�H�-�ij�h�A!�4�j�h���a�L���Z��K1A�xY�Xz=A�hq�Z�
�ZP)���
����Q�%I�h��H���KIPI���!��ap��?�NQ��Q�Q�Q��QQQQ����Ԟ����@�d����IY��[�ZH��ѐJ�X�Y���-��XI-����*�I��iYh�Qa�4�҃A������q�5�yq�Z5A�xqXA�-���Ӟ>K[���h���K�Y�JA5�aQ�ݍ��ؐz��<h<�����J�B��QQQQQ�x�i�Hˆ���e�'��[�Z�Y�J�X�YZX��XФ�٣���a���Q��і!�J�z��Ѵ�a�H�X���p��yIa���+���[5A�hq�X5A�xq�Z^8�a���8[JJ�JHJHJA�Ԕ�jQAː-�M�K��y��)%�]�HHJJJJ�J�JJJJJJJ�Q���`˃('��xq�ؘ�0�ii�J�Y��KY��XH
���=Q���J��I-�iY��H�I�i���і%aJ�z6����>K��I��Q�X5A�QY�Yl�X�-�:P�r��jh	�AѴ`��A5I�Ѵha���
�X����y�[�����⼲Ø������`�ؘqp�����I5ky�ai�H���ӫ�X`���A%�
���h�(��Ii��҃A���F似Z�KqXY�Izy<�yQ�Z�����~��$JY�hh��`aj�JI���!��a�����	JJJJJJJ�J�JJJ�������a���0�hI㏲=��a�=P�HY��[�ZH[�ѐJ�X�O����A��҃A����I-i�����I�iAIh��T��
��jzY�K=A�xq�Xj5I�Qټ�0����<�%n�J�A�A�A�@��IaI�H���`˃*�������-����������LaA�A�A�������8@�d�����€�Y�[�ѐJ�X�Y^�Z�X�a���C��p����Aa��X������A%���j�h�yI��+���KqA�zY�Yz=�hy�Z�ڸi�H�Ӛ>K[���HJHP�QaJH�aA7�=��	K���˘x��QaQ�Q��Q�QQQ��Q���-�M�<@�6�����Y����Z�ِJ�X�Y^��X�a��� Ih�і%a��zц�Q�!�J�z����Qa�5%�����I�jy�Z�I���y�Z=I�x��a����:�� JI�h��AJA��Ha��p‹,G�(�k�Ӡ�=�NaQaQQ�Q��QaQ�Q�Q������q�ˆ���e�'���J��ѰɐZ�X�YЭ�������Y�IP�AeQa�0�h�h���a��e�h��0=���q�j=A��Y�Yz=�Y�Ylڸi�H���)J[JAJ���Q��p��@�Aڸi�HŽ,Ke+�����������򴲴�������Д�L�hx}�aҒ������t��a�yy�Ii��eY���p�������ԴIi��j�@$a����h�Ѷ%a��j��b��>K��Y�KqA�zY�Xz=A��Y�񼒴Xc�=Ga��`J���A�j�	�HaYpH��i.=�e�i�-�%%��A�A
A�A�A�aa�AJAaJJh�a��HڔiV�Y��Aa�Y��Y^�Z�X��������P��RVI-�j��$�H������AH���i�h�yIe�PG���xq�Xz=A��Y�Xz=I�Q��&!�����Pa��@A�A�A��hHіIYPڸ&!��a���I11113%J�h�&!�Ҙ	�/�	O��J€�ZH[�ѐJ�X�Y�YZ����C�Qa����j�@$a��Jц�і%a��AIh��T��
��JhY�Z=I�xqXjY�Yj�NԎ�����
�=��@��H%I�h�PaHph������K��y���)�A�A�A�A�A�A�aAaQaQQ�i.�Xc�I�������x�A����Н�i�A9cy�iZ%��P@�h��0H�h�h���a�0e�h�h.@��F�似Z��K5A�xyXzQ�Yjy��
�X��ֺ�cֶhIlKj��Q�QA��Aj�A����
�Z����y�[��������’����8b�d��I�
y�Y�eY��[�J��X�.���0*��I-�i��h�Q%�-�ijh�eQa��j2�ܜ��0�jY�[5A�xyXzQ�Yzy��y-i��˘<t���A�A����AQA���H���`�(��˩����X%JJJJJJJJ��������r����dP��Z�[�ZH[�ѐA�ZX�]���‚Z����Ѷ%a��JY��і%a��Ih��T��
��JjQ�[5A�xyXzQ�Yj�NЎ�����
�=��@���K�IPajHPh������K�����x)��AAAJ�A�QaaaQQ�h�a�Һ����8�Y^�Z�X���������I=�c�����і!a�J����Qa��I-j��H�Hv����>K��I��Q�Xz=A�QQ�Xz5A�<}��A�=PGq�.���@���h��A�H��AQ
��<}�z��-N���`�QaQaQ�Q�Q�Q�QaQQ�Q�����]d:>Ԣ򞜺i`X�Y^�Z�X������������
AJQ��іa�J�I-Q�a��I-�Aj��5%�����H<Y�Z=I�xy�XQ�YJ��G����:��(�JI�h��AJA��IaYpB�.G�h�k�Ӡ�=�NaQaQaQ�Q��QQ�Q�Q�����0���Q��=Ҫap��%aYI�Y�e�X�ZH�������HԔI-�iY@�֔Ii��j���HִIi�È��8�Y�K5A�y�XY�IzyX���X�����QAn�j�HPHPHa-��YPQ-��i���X
ܸ��=��b����A�A�A�A�A
A
A�A��h<-�zaZЀ�ؼ��,h�ZX�Y^������ЖaI=�c����Q�hj����I�-ij���H�I�i��j�Q�e�]Z�!����I�j1�iq�ZkY�KqA����!D؜��
��Z��@��JHPH%j�@���AQ��4��6��{�[�@`L
�A�AA
�A
HH��-��<@�d�+)RVI�ei��
eY��[�Z�ِJ
���Aa�4�j�h�Qa�0�h�h���a��hr��ؾ>�
Q�Xe=I��Y�Yz=A��Q��y-i��K����@A�@Q�Q�і�IQn�	a�z�$�¡������-�Q������򴲴�����������i.�Xa�I�������y�I����Н�i�A9q�aZ%��P��h$�0�h�h.��0e�h�h����L,�aɼZ��K5A�xyXjQ�Yl���
�X��ֺ�cֶ�I�IYpH��QA��A*�A����
�X����y�[��������x�i�Hˆ����$�A��JY���ɐZ���Xҭ���L�
�Р���h�eQa��j�h$�0H�h�h���I��qX�e5I��Y�Xz=I��Q�Yzڸ������|yh	�JA-���ѴhI��	�h�!����H�,Kei���QQQQQQQ�Q�������
�ZҸ<>Բ⎌��@P[�ѐJ�Z�X�YZX��Н�aPN��RVXH�����*��I��ij�h�(��I-�i�h�yIa���+���Z5A�hy�XzY�Yz=A�QJ�&Xi�>�
�h��@A�A�A��hI�0AI�Pڸ���H���0�ښ�	JJJJJJJJJJJJJJJJJJJJJ�h<m�at�:�ظ���h�Z�X�Xҭ�����I5y�����@�hj���H�-ij��HԔI)�ij�@�eօ�!���M�hqXjY�Iz=�Y�Y�
�ZҸǫ�
��j��@��JHPHPQ��Ijh�������{�[�@$Ea
a�AAA�A
�A��hB�,E�h���/�	O�PPZX�X�YZ�X��Е�i�Iyc��$�A�%ِXA��AI�і%a��z���Qa�Z%�����H�jy�Z�I�<ry�ZI�<��6���:��$JAI�h��H@��I�j�PI��E�,�{�[�`�HHHHHHHHHHHJJJJJJJJJJ������Ԣ򜼺i�EX����eIy�q�Ai��e��ӫ�P$��a��I)j�AH�-�ijh�Q%�-����
��hy�ZkY�KqA�xY�X�-�:P�r���@��@���h��Ajj��A�j�<-�:�-����`�Q�QQ�Q�Q�QQQ���x�i�Hˆ����$�AJ�Y�J�X�Y^�Z�X������p��
�@�h���a�0H��h.��J��I-�i��Z0-
�aɼZ��KqA�hY�Xz=I�QY�X�
�ZҸ׻�c��Z��`��HHPHPQ��KY�@A����
�ZҸ�y�[�����
Is the serial monitor set to the matching baud rate?
What IR sensor are you using? I use TSOP38238 successfully with the IRRemote library.
What version of the library are you using? I'm using 4.4.0 and it seems the library isn't
anymore, but
#include <IRremote.hpp>
and other changes from the older versions of the library.
So you could make sure your code is supported by rolling back your library (if it's the case that you're using the new one), or make all the necessary changes found here:
