Feasibility of a temperature gauge
Hi, I relatively new to programming and am just wondering what the best way would be to make a real-time temperature gauge using a DS18B20 and a servo,
Thanks for taking the time to read this and any assistance would be much appreciated,
Cheers,
John
What was your investment in finding an answer to your question?
Here's mine:
http://playground.arduino.cc/
http://playground.arduino.cc/Learning/OneWire
http://playground.arduino.cc/ComponentLib/Servo
Yeah, I've looked through all the normal sources and spent hours searching around and trying but cannot find anything that uses it as a gauge, only a valve that opens at a certain temperature and I'm not skilled enough to complete the coding involved but thanks anyway
So you want the servo to move back and forth based on a temperature reading that is always changing?
Also curious as to what you want to do. I'm imagining a big thermometer with a servo driven hand.
What I would do is deal with each piece of hardware separately at first. I'd write a sketch to output the thermometer values to the serial monitor. Then I'd do a sketch to deal with the servo. Then I'd go back and combine them, using what I learned about them.
Why not use an LCD screen instead of a servo? I have a code that you can modify to work with a TFT screen.
Johndimo that's it basically yeah and I had attempted to code each and then piece it together but I couldn't quite get it working
Post 'it' here and describe what 'it' does or doesn't do, then it will be easier to give advice
Start with the servo "knob" code example in the arduino IDE and then use the sensor output instead of the knob pot output.
Hi, I have made at one stage a humidy and temp display using a couple of servos as big meters, I only did it as an exercise but I may be able to find the sketch for you.
Otherwise try:
They may help, I'm sure I've seen one in instructables too.
Tom...... :slight_smile:
