Ich habe eine Funktion motor(); aus einem Programmteil erstellt der immer wieder zum Einsatz kommt. Das vereinfacht den Code ein wenig und macht es übersichtlicher.
Nun bekomme ich aber immer den Fehler: 'motor' was not declared in this scope. Warum? Klammern sind alle da was ich sehe und sonst sollte es doch auch gehen? Wo liegt der Hund begraben?
Pin configuration:
Roboclaw 2x7A => TX Pin D7 //Motor controller for dome drive (Roboclaw Pin S1) => RX
Roboclaw 2x60A => RX Pin D6 //Motor controller for feet drives (Roboclaw Pin S2, left/right) => TX
TX Pin D5 //Motor controller for feet drives (Roboclaw Pin S1, forward/reverse) => RX
Arduino MEGA, SCL #0x3A => Pin D19 //SCL, master device
Arduino MEGA, SDA #0x3A => Pin D18 //SDA, master device
Arduino UNO, MP3 Shield TX => Pin D10 //RX
Arduino UNO, MP3 Shield RX => Pin D11 //TX
/**SETTINGS**/
const unsigned long Baudrate = 38400; //starts serial port with a baudrate by 38400 b/s
const byte SpeedDD = 80; //set the speed for dome drive (127=full speed, 0-127 slower to faster)
const byte SpeedFDLR = 100; //set the maximum, normal speed for foot drive left/right (0=stop, 127=full speed, 0-127 slower to faster)
const byte SpeedFDUD = 100; //set the maximum, normal speed for foot drive forward/backward (0=stop, 127=full speed, 0-127 slower to faster)
const byte SpeedFDLRfast = 120; //set the maximum, fast speed for foot drive left/right (if joystick is pressed down) (0=stop, 127=full speed, 0-127 slower to faster)
const byte SpeedFDUDfast = 120; //set the maximum, fast speed for foot drive forward/backward (if joystick is pressed down) (0=stop, 127=full speed, 0-127 slower to faster)
#define address 0x80 //address for Roboclaw from feet motors, address 128
#define addressDD 0x82 //address for Roboclaw from dome motor, address 130
//Definition of pinnumbers
#define RoboclawDomeTXpin 7 //Software serial Roboclaw dome drive TX defined on pin D7
#define RoboclawRXpin 6 //Software serial Roboclaw foot drive RX defined on pin D6
#define RoboclawTXpin 5 //Software serial Roboclaw foot drive TX defined on pin D5
#define RXpin 10 //Software serial RX defined on pin D10
#define TXpin 11 //Software serial TX defined on pin D11
//Definition of designations for reading signals (signals to be received)
byte DD = 0; //Dome drive
byte FDLR = 0; //Foot drive left/right
byte FDUD = 0; //Foot drive forward/backward
byte joybut = 0; //Foot drive joystick-button
byte BUT1 = 0; //Button 1
byte BUT2 = 0; //Button 2
byte BUT3 = 0; //Button 3
byte BUT4 = 0; //Button 4
byte BUT5 = 0; //Button 5
byte BUT6 = 0; //Button 6
byte BUT7 = 0; //Button 7
byte BUT8 = 0; //Button 8
byte BUT9 = 0; //Button 9
byte BUT10 = 0; //Button 10
byte BUT11 = 0; //Button 11
byte BUT12 = 0; //Button 12
byte BUT13 = 0; //Button 13
byte BUT14 = 0; //Button 14
byte BUT15 = 0; //Button 15
byte BUT16 = 0; //Button 16
byte BUT17 = 0; //Button 17
byte BUT18 = 0; //Button 18
byte BUT19 = 0; //Button 19
byte BUT20 = 0; //Button 20
byte BUT21 = 0; //Button 21
byte BUT22 = 0; //Button 22
byte BUT23 = 0; //Button 23
byte autobut = 0; //Automatic button
//Definition of designations for storing signals (cache)
byte data[5]; //create array for packet serial (feet and dome motors)
uint16_t crc = 0; //checksum crc
byte retry = 2; //number of retried transmissions if failed
volatile byte dataReceived[2]; //byte array for received data over I2C
bool newData; //check for new data received
byte lastDD = 0; //last status from dome drive
byte lastFDLR = 0; //last status from foot drive, left/right
byte lastFDUD = 0; //last status from foot drive, forward/backward
byte mapFDLR = 0; //converted value FDLR (foot drive left/right) for the dc motor
byte mapFDUD = 0; //converted value FDUD (foot drive forward/backward)( for the dc motor
byte mapDD = 0; //converted value DD (dome drive left/right) for the dc motor
#include <Wire.h> //adds library for I2C
#include <SoftwareSerial.h> //adds library to define software serial ports
SoftwareSerial serial1(RXpin, TXpin); //create software serial "serial1" with RX, TX pins
SoftwareSerial Roboclaw(RoboclawRXpin, RoboclawTXpin); //create software serial "Roboclaw" with RX, TX pins
SoftwareSerial RoboclawDome(8, RoboclawDomeTXpin); //create software serial "RoboclawDome" with RX, TX pins
Wire.begin(0x3A); //starts I2C bus as slave on address 0x3A
Wire.onReceive(readCommand); //function to trigger when something is received over I2C
//definition of input/output pins
pinMode(RXpin, INPUT); //pin RXpin is an input
pinMode(TXpin, OUTPUT); //pin TXpin is an output
pinMode(RoboclawRXpin, INPUT); //pin RoboclawRXpin is an input
pinMode(RoboclawTXpin, OUTPUT); //pin RoboclawTXpin is an output
pinMode(RoboclawDomeTXpin, OUTPUT); //pin RoboclawDomeTXpin is an output
serial1.begin(Baudrate); //starts serial1 port with a baudrate by "Baudrate" (b/s)
Roboclaw.begin(Baudrate); //starts roboclaw port with a baudrate by "Baudrate" (b/s)
RoboclawDome.begin(Baudrate); //starts roboclawDome port with a baudrate by "Baudrate" (b/s)
//initialization of the dome motor on startup
motor(0,0, addressDD, RoboclawDome); //command for forward, stop movement, address, serial port
//initialization of the feet motors on startup
motor(10,0, address, Roboclaw); //command for turn right in mix mode, stop movement, address, serial port
motor(8,0, address, Roboclaw); //command for forward in mix mode, stop movement, address, serial port
if(newData == true){ //if new data received is true, then make...
//Dome drive
if(DD != lastDD){ //if DD (dome drive) not equal to lastDD, then make...
if(0 <= DD && DD < 87){ //if DD is between 0 and 90, then make...
mapDD = map(DD, 90, 0, 0, SpeedDD); //read value from DD, convert the input value from 0 to 90 in a dc motor value from 0 to SpeedDD and store it to mapDD
motor(0,mapDD, addressDD, RoboclawDome); //command for forward, movement mapDD, address, serial port
else if(180 >= DD && DD > 93){ //if DD is between 90 and 180, then make...
mapDD = map(DD, 90, 180, 0, SpeedDD); //read value from DD, convert the input value from 90 to 180 in a dc motor value from 0 to SpeedDD and store it to mapDD
motor(1,mapDD, addressDD, RoboclawDome); //command for backward, movement mapDD, address, serial port
else if(87 <= DD && DD <= 93){ //if DD is 90, then make...
lastDD = DD; //stores DD on lastDD
//Foot drive
if(FDLR != lastFDLR && joybut == HIGH){ //if FDLR (foot drive left/right) not equal to lastFDLR and joybut is equal to HIGH (not pressed), then make...
if(0 <= FDLR && FDLR < 87){ //if FDLR is between 0 and 90, then make...
mapFDLR = map(FDLR, 90, 0, 0, SpeedFDLR); //read value from FDLR, convert the input value from 0 to 90 in a dc motor value from 0 to SpeedFDLR and store it to mapFDLR
motor(10,mapFDLR, address, Roboclaw); //command for turn right in mix mode, movement mapFDLR, address, serial port
while(Roboclaw.available() > 0) {
if(Roboclaw.read() != 0xFF){
for(retry=2; retry > 0 && Roboclaw.read() != 0xFF; retry--) {
//Serial.print("retry = ");
//Serial.println(map(retry,2,0,0,2));
delay(10);
Roboclaw.write(data, sizeof(data));
retry = 2;
else if(180 >= FDLR && FDLR > 93){ //if FDLR is between 90 and 180, then make...
mapFDLR = map(FDLR, 90, 180, 0, SpeedFDLR); //read value from FDLR, convert the input value from 90 to 180 in a dc motor value from 0 to SpeedFDLR and store it to mapFDLR
motor(11,mapFDLR, address, Roboclaw); //command for turn left in mix mode, movement mapFDLR, address, serial port
else if(87 <= FDLR && FDLR <= 93){ //if FDLR is 90, then make...
lastFDLR = FDLR; //stores FDLR on lastFDLR
if(FDLR != lastFDLR && joybut == LOW){ //if FDLR (foot drive left/right) not equal to lastFDLR and joybut is equal to LOW (pressed), then make...
mapFDLR = map(FDLR, 90, 0, 0, SpeedFDLRfast); //read value from FDLR, convert the input value from 0 to 90 in a dc motor value from 0 to SpeedFDLRfast and store it to mapFDLR
mapFDLR = map(FDLR, 90, 180, 0, SpeedFDLRfast); //read value from FDLR, convert the input value from 90 to 180 in a dc motor value from 0 to SpeedFDLRfast and store it to mapFDLR
if(FDUD != lastFDUD && joybut == HIGH){ //if FDUD (foot drive forward/backward) not equal to lastFDUD and joybut is equal to HIGH (not pressed), then make...
if(0 <= FDUD && FDUD < 87){ //if FDUD is between 0 and 90, then make...
mapFDUD = map(FDUD, 90, 0, 0, SpeedFDUD); //read value from FDUD, convert the input value from 0 to 90 in a dc motor value from 0 to SpeedFDUD and store it to mapFDUD
motor(8,mapFDUD, address, Roboclaw); //command for forward in mix mode, movement mapFDUD, address, serial port
else if(180 >= FDUD && FDUD > 93){ //if FDUD is between 90 and 180, then make...
mapFDUD = map(FDUD, 90, 180, 0, SpeedFDUD); //read value from FDUD, convert the input value from 90 to 180 in a dc motor value from 0 to SpeedFDUD and store it to mapFDUD
motor(9,mapFDUD, address, Roboclaw); //command for backward in mix mode, movement mapFDUD, address, serial port
else if(87 <= FDUD && FDUD <= 93){ //if FDUD is 90, then make...
lastFDUD = FDUD; //stores FDUD on lastFDUD
if(FDUD != lastFDUD && joybut == LOW){ //if FDUD (foot drive forward/backward) not equal to lastFDUD and joybut is equal to LOW (pressed), then make...
mapFDUD = map(FDUD, 90, 0, 0, SpeedFDUDfast); //read value from FDUD, convert the input value from 0 to 90 in a dc motor value from 0 to SpeedFDUDfast and store it to mapFDUD
mapFDUD = map(FDUD, 90, 180, 0, SpeedFDUDfast); //read value from FDUD, convert the input value from 90 to 180 in a dc motor value from 0 to SpeedFDUDfast and store it to mapFDUD
newData = false; //set new data received to false for receiving new data
//Function for reading a command and store it to designation
void readCommand(int bytes){ //function readCommand takes the length of received data (bytes) from onReceive and make...
if(bytes == 2){ //if bytes is equal to 2 (received bytes), then make...
dataReceived[0] = Wire.read(); //store the first byte from received data over I2C to dataReceived array
dataReceived[1] = Wire.read(); //store the second byte from received data over I2C to dataReceived array
switch(dataReceived[0]){
case 'X' : DD = dataReceived[1]; //if the first byte in the array dataReceived is equal to X, then store the second byte from the array dataReceived to DD
break; //finish the command and return
case 'Y' : FDLR = dataReceived[1];
case 'Z' : FDUD = dataReceived[1];
case 'd' : joybut = dataReceived[1];
case 'e' : BUT1 = dataReceived[1];
command('e',BUT1, serial1); //send command e and the value from BUT1 over serial to the next Arduino
case 'f' : BUT2 = dataReceived[1];
command('f',BUT2, serial1);
case 'g' : BUT3 = dataReceived[1];
command('g',BUT3, serial1);
case 'i' : BUT5 = dataReceived[1];
command('i',BUT5, serial1);
case 'j' : BUT6 = dataReceived[1];
command('j',BUT6, serial1);
case 'k' : BUT7 = dataReceived[1];
command('k',BUT7, serial1);
case 'm' : BUT9 = dataReceived[1];
command('m',BUT9, serial1);
case 'n' : BUT10 = dataReceived[1];
command('n',BUT10, serial1);
case 'o' : BUT11 = dataReceived[1];
command('o',BUT11, serial1);
case 'q' : BUT13 = dataReceived[1];
command('q',BUT13, serial1);
case 'r' : BUT14 = dataReceived[1];
command('r',BUT14, serial1);
case 's' : BUT15 = dataReceived[1];
command('s',BUT15, serial1);
case 't' : BUT16 = dataReceived[1];
command('t',BUT16, serial1);
case 'u' : BUT17 = dataReceived[1];
command('u',BUT17, serial1);
case 'v' : BUT18 = dataReceived[1];
command('v',BUT18, serial1);
newData = true;
//Function for sending a command over serial
void command(const char command, const byte value, Stream& stream){
stream.print(command);
stream.println(value);
//Function for driving the feet and dome motors over serial
void motor(const byte command, const byte value, const byte address, Stream& stream){
data[0] = address; //write address in data array
data[1] = command; //write command for forward/reverse/left/right in data array
data[2] = value; //write movement speed in data array
for(byte index = 0; index < 3; index++){ //create the checksum for the array data[i] with 0 <= i <= 3
crc16(data[index]); //call the function crc16
//crc = getCRC();
data[3] = crc >> 8; //store checksum in data array
data[4] = crc;
stream.write(data, sizeof(data)); //send the data array by serial
crc = 0; //clear the checksum
//Calculates CRC16 of nBytes of data[index] in byte array
void crc16(uint8_t data) {
int i;
crc = crc ^ ((uint16_t)data << 8);
for (i=0; i<8; i++){
if (crc & 0x8000){
crc = (crc << 1) ^ 0x1021;
else{
crc <<= 1;
uint16_t getCRC() {
return crc;
