Fibonacci Weirdness
I wrote a simple program to display Fibonacci numbers to a 16x2 LCD screen.
Here is the loop portion:
  int a = 0;
  int b = 1;
  for (int i = 0; i < 20; i += 1)
    myDisplay.setCursor(0, 1);
    myDisplay.print(a);
    int c = a + b;
    a = b;
    b = c;
    delay(analogRead(A0));
Clearly, this should display the first 19 Fibonacci numbers, and then start over at zero. But it doesn't. at its current setting (i < 20), it displays the first 19 numbers just fine, and then starts doing a weird digit increment thing. (starts at 131, then 1131, then 2131, and so on until it wraps, then repeats with the wrapped digits).
I'm so confused as to why. The first thing I do in the main loop is declare a and b as 0 and 1 respectively, what's going on here?
integers have a limited range, try to make the type uint32_t or even uit_64_t
Note your loop only goes to the 20th number
try this variation
//    FILE: fibonacci.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.0.1
// PURPOSE: demo
// HISTORY:
uint32_t a = 0;
uint32_t b = 1;
int cnt = 0;
  Serial.println(__FILE__);
  Serial.print(cnt++);
  Serial.print("\t");
  Serial.println(a);
  uint32_t c = a + b;
  a = b;
  b = c;
  delay(100);
0	0
1	1
2	1
3	2
4	3
5	5
6	8
7	13
8	21
9	34
10	55
11	89
12	144
13	233
14	377
15	610
16	987
17	1597
18	2584
19	4181
20	6765
21	10946
22	17711
23	28657
24	46368
25	75025
26	121393
27	196418
28	317811
29	514229
30	832040
31	1346269
32	2178309
33	3524578
34	5702887
35	9227465
36	14930352
37	24157817
38	39088169
39	63245986
40	102334155
41	165580141
42	267914296
43	433494437
44	701408733
45	1134903170
46	1836311903
47	2971215073
48	512559680
note for uint64_t you need to add 64 bit support for Serial.print.
OK as it is weekend, here a 64 bit version
// VERSION: 0.0.1
// PURPOSE: demo
// HISTORY:
uint64_t a = 0;
uint64_t b = 1;
int cnt = 0;
  Serial.print('\t');
  // 64 BIT PRINT
  char s[28];
  int idx = 0;
  uint64_t t = a;
  while (t > 0)
    s[idx++] = (t % 10) + '0';
    t = t / 10;
  idx--;
  while (idx >= 0)
    Serial.print(s[idx--]);
  uint64_t c = a + b;
  a = b;
  b = c;
  delay(100);
And then there is the big number class from Nick Gammon ....
you can add these lines to find (approx) the Golden Ratio
Serial.print('\t');
Serial.print((float)a/(float)b, 7);
converged quite fast
0		0.0000000
1	1	1.0000000
2	1	0.5000000
3	2	0.6666667
4	3	0.6000000
5	5	0.6250000
6	8	0.6153846
7	13	0.6190476
8	21	0.6176471
9	34	0.6181818
10	55	0.6179775
11	89	0.6180556
12	144	0.6180258
13	233	0.6180372
14	377	0.6180328
15	610	0.6180344
16	987	0.6180338
17	1597	0.6180341
18	2584	0.6180339
19	4181	0.6180340
20	6765	0.6180340
21	10946	0.6180340
22	17711	0.6180340
you can calculate nth Fibonacci directly with the golden ratio + 1 (PHI)
//    FILE: fibonacci3.ino
// VERSION: 0.0.1
// PURPOSE: demo
// http://www.maths.surrey.ac.uk/hosted-sites/R.Knott/Fibonacci/fibFormula.html
const double PHI = 1.61803398874989484820;
int cnt = 0;
  for (int i = 0; i < 92; i++)
    Serial.print(i);
    Serial.print('\t');
    // Binet's Formula for the nth Fibonacci number
    uint64_t a = round(pow(PHI, i) * (1.0 / sqrt(5)) );
    // 64 BIT PRINT
    char s[28];
    int idx = 0;
    uint64_t t = a;
    while (t > 0)
      t = t / 10;
    idx--;
    while (idx >= 0)
    delay(100);
however it fails on the Arduino somewhere at 29th number
challenged by fibonaci I tried to find largest fibo number an Arduino UNO could generate and print.
It ended here with a 1778 digit nr. (Given 2K RAM that is not too bad)
//    FILE: Fibonaci4.ino
// VERSION: 0.1.0
// PURPOSE: Generate Largest Fibonaci numbers possible with an UNO
// 880 ==> F8423  1760 digits
// 885 ==> F8471  1770 digits
// 886 ==> F8480
// 887 ==> F8490
// 888 ==> F8499
// 889 ==> F8509  1778 digits;  even F8511 is also correct
// 890 ==> FAIL    (probably stack meets heap)
#define NR 889
// every byte holds 2 digits 00..99,  so up to 2xNR digits
uint8_t a[NR];
uint8_t b[NR];
  memset(a, NR, 0);
  memset(b, NR, 0);
  b[0] = 1;
  for (int x = 0; x <= 8515; x++)     //  <=  NR * 10
    if (x > 8500)  // (un)comment this line to see them all
      Serial.print(x);
      Serial.print('\t');
      for (int i = NR - 1; i >= 0; i--)
        if (a[i] < 10) Serial.print(0);
        Serial.print(a[i]);
    add();
void add()
  for (int i = 0; i < NR; i++)
    uint8_t t = a[i] + b[i];
    a[i] = b[i];
    b[i] = t;
  // overflow correction,
  // only for b[] if we do 2 loops
  // merge loop with above loop and a[] needs to be corrected too
  for (int i = 0; i < NR - 1; i++)
    if (b[i] >= 100)
      b[i] -= 100;
      b[i + 1] += 1;
So the largest fibonaci number I could generate with an UNO was F8509.
F8510 and F8511 did overflow but were correctly printed.
8509	84400668190831278333126686020568946106614003082504815691896926120086131519066530270401365150210042570035634084935763826819099864112979376961661562417793900681836132737090783699187109752346894362146729443861932954797103558698690088556386363449839100798233428510045574404281650986095441352642766043355163610653801755941962458167776501827784067503772352220365476497251345399470656860558030204409880089039247426617320988738496392544021299822651623000444688282162592047232218746545194397654235083898448444745534967097958514311764995238775243162423291637586000207022796813218200598823807327545244893853216782407867479609892957746756822160315419219333173267392387825370120933834142318412505363382985472450967190350898502590685605876779301683036360354833085165222061655724331245008230894055479640998738672579350359616870897812480325092527549497779593983301658570788354314745461537933275154142846590337032275039396449662376080498360032118515390445213501565130538536367778461502545284853684869398312395906117279593258790138160015179339987928198402182503160808688764734348834481750099824697010799278937674376188007828065969973640859570189762195644772095085422354304121126909891490625344248410538967407128607033202635969935371117360366864194348298251565603036430286887699099574221488502532072212488664328217204094709791039588860704985604667942339738618630894438821813765433687821257650143695575216820605231112636773195666608116456908598045789161175106064241425067968307295582078012780293816412407165162239036229160909093238098333484300645840988885499648511476316906418259117725435323768154132836313652410150734466934385809642129791779055728697968868506140269519165712151562215621865405371741470824129239460211934080304413941783141547696833805271120951873987471301204306728566019963363270409
8511	220963817996798382910942772294426478096573113748757492444211706032603575028591589591830285820181857288071945503473881874755185832405608652208370453626383399498373507887413896700021031583605068993699743964022518831552203828441069209318004831457059988706854031043374552590129600055045646363813205304964329481126802679494093360645804279491652605011003831901896741617761752671547027624329981936920524476377116158769104548177899398782298078887817120245647193565893469631194914570055245914810246996267651056211573182808748490237920841748891626304104135517230402463120077711439851049323993973947710690752756803978290099416912586389146424532072048811768746420975498862552999402574098307714950819218036994630092546589976348370092002546007819888628846908652500941980926903888991682006584195372121784829683276479352411538689383612960646990184524429690119324797671646093961719666867656003489685665209101882844307101747721764553693812952073858069783545221835535173615054035257155793467934420974677612289049423661352961792301593082438708415564194769954765206466541396807998052334191754355823342020945469270470202632919037338484220322542625375882922427051697644991224086194358490554610430982412129342140226509949447597273676544951062705831602340721195389756916654472039385591541543850886536025299207383876172644619438002510141948329977963452472363655321302684635199172816446191451933714077890660824903056716986422613669658605709411760697783344526510071376831256243555309547600620480923020443550192801708401670414714824474072165043960875820848983400464618459578453377462052499028665974815088915198899357880162747105076981008710925856544810072426352731767850525487316189144739470633075448884498455974169432192372680233790740495494456074584572342652021829213816783887042631031915935993185842879714
Note: at 115Kbaud one can print ~10000 chars per second or ~5 fib numbers of this length.
printing all 8500 will take almost 30 minutes.
(and no they will not fit on an LCD anymore)
fun!
using an array of uint32_t I can squeeze 9 digits in 4 bytes instead of 8 in the code above.
using the same technique I now get a fibonacci number of 1999 digits with an UNO.
//    FILE: Fibonacci5.ino
// VERSION: 0.1.0
//    DATE: 2018-03-04
// PURPOSE: Generate Largest Fibonacci numbers possible with an UNO
// 222 ==> F9565  1999 digits;
// 223 ==> FAIL   (stack meets heap)
#define NR 222
// every element holds 9 digits 0..999999999,  so up to 9xNR digits
// except the last can hold 1 digit more .
uint32_t a[NR];
uint32_t b[NR];
  b[0] = 1;
  for (int x = 0; x <= 9600; x++)     //  x <=  NR * 45
    if (x > 9500)  // (un)comment this line to see them all
      Serial.print(x);
      Serial.print('\t');
        if (a[i] < 100000000) Serial.print(0);
        if (a[i] < 10000000) Serial.print(0);
        if (a[i] < 1000000) Serial.print(0);
        if (a[i] < 100000) Serial.print(0);
        if (a[i] < 10000) Serial.print(0);
        if (a[i] < 1000) Serial.print(0);
        if (a[i] < 100) Serial.print(0);
        Serial.print(a[i]);
    add();
void add()
    uint32_t t = a[i] + b[i];
    a[i] = b[i];
    b[i] = t;
    if (b[i] >= 1000000000)
      b[i] -= 1000000000;
      b[i + 1] += 1;
To squeeze more I have to use uint64_t elements, but printing would be more complex.
64 bit could have 19 digits instead of 18 so max ~5% more ==> about 2100 digits should be possible
To me it looks like the printing is done without clearing the screen, leaving some leftover chars on the LCD when restarting at i=1.
Either print some blank chars after printing a, or clear the screen after the 'for' loop
(still off topic)
uint64_t version ==> F9820 -- 2052 digits.
//    FILE: Fibonacci6.ino
// VERSION: 0.1.0
//    DATE: 2018-03-04
// 108 ==> F9820  2052 digits;
// 109 ==> FAIL   (stack meets heap)
#define NR 108
// every element holds 19 digits
uint64_t a[NR];
uint64_t b[NR];
  Serial.begin(230400);
  b[0] = 1;
  for (int x = 0; x <= 9825; x++)     //  x <=  NR * 45
    if (x > 9810)  // (un)comment this line to see them all
      Serial.print(x);
      Serial.print('\t');
        if (a[i] < 1000000000000000000ULL) Serial.print(0);
        if (a[i] < 100000000000000000ULL) Serial.print(0);
        if (a[i] < 10000000000000000ULL) Serial.print(0);
        if (a[i] < 1000000000000000ULL) Serial.print(0);
        if (a[i] < 100000000000000ULL) Serial.print(0);
        if (a[i] < 10000000000000ULL) Serial.print(0);
        if (a[i] < 1000000000000ULL) Serial.print(0);
        if (a[i] < 100000000000ULL) Serial.print(0);
        if (a[i] < 10000000000ULL) Serial.print(0);
        if (a[i] < 1000000000ULL) Serial.print(0);
        if (a[i] < 100000000ULL) Serial.print(0);
        if (a[i] < 10000000ULL) Serial.print(0);
        if (a[i] < 1000000ULL) Serial.print(0);
        if (a[i] < 100000ULL) Serial.print(0);
        if (a[i] < 10000ULL) Serial.print(0);
        if (a[i] < 1000ULL) Serial.print(0);
        if (a[i] < 100ULL) Serial.print(0);
        if (a[i] < 10ULL) Serial.print(0);
        print64(a[i]);
    add();
void add()
  uint64_t overflow = 0;
  // max64_t 18446744073709551615
  for (uint8_t i = 0; i < NR; i++)
    uint64_t invert = 10000000000000000000ULL - a[i];
    if (invert > b[i])
      uint64_t t = a[i] + b[i];
      a[i] = b[i];
      b[i] = t;
      if (overflow) b[i]++;
      overflow = 0;
      // overflow prevention,
      uint64_t t = b[i] - invert;
      a[i] = b[i];
      b[i] = t;
      overflow = 1;
void print64(uint64_t t)
  // 64 BIT PRINT
  char s[24];
  int idx = 0;
  while (t > 0)
    t = t / 10;
  idx--;
  while (idx >= 0)
(still off topic)
squeeeeeezed 19 extra digits -> F9911 == 2071 digits
I can see F10000 at the horizon...
// VERSION: 0.1.0
//    DATE: 2018-03-04
//     URL: https://forum.arduino.cc/index.php?topic=532760.0
// 109 ==> F9911  2071 digits
// 110 ==> FAIL
#define NR 109
uint64_t a[NR];
uint64_t b[NR];
  b[0] = 1;
  for (int x = 0; x <= 9920; x++)     //  x <=  NR * 45    10100
    if (x > 9900)  // (un)comment this line to see them all
      Serial.print(x);
      Serial.write('\t');
      for (int8_t i = NR - 1; i >= 0; i--)
        print64(a[i]);
      Serial.write('\n');
    add();
void add()
  uint8_t overflow = 0;
    // detect overflow
    uint64_t t = 10000000000000000000ULL - a[i];
    if (t > b[i])
      t = a[i] + b[i];
      a[i] = b[i];
      b[i] = t;
      overflow = 0;
      t = b[i] - t;
      a[i] = b[i];
      b[i] = t;
      overflow = 1;
  // 64 BIT PRINT
  char s[20];
  int8_t idx = 0;
  while (t > 0)
    t = t / 10;
  while (idx < 19) s[idx++] = '0';  // leading zeros
  idx--;
  while (idx >= 0)
    Serial.write(s[idx--]);
update:
Found a bug in this code, the overflow is not handled correctly in some corner cases.
The algorithm fixes this in next iteration but some values are printed incorrect.
(version 5 is ok afaik)
Working on a fix - and a even more squeezed version.
(final fibonacci version for now)
Squeezed 63 digits more out of the UNO - F10209 - 2134 digit number
by using optimized packed array of 10 bit numbers (which caused slow code and other discomfort)
Verified numbers against python script,
//    FILE: Fibonacci7.ino
// VERSION: 0.1.2
//    DATE: 2018-03-05
// PURPOSE: Generate large Fibonaci numbers with an uno
   Program uses compacte groups of 3 digits = 0..999
   This fit in 10 bit giving a storage efficiency of 1000/1024 ~ 97%
   (it has just enough spare to tackle overflow.
   two arrays of 890 bytes can represent an 2136 digit number.
   however packing and unpacking is slow.
   @890 memory is minimal.
   Global variables use 1964 bytes (95%) of dynamic memory,
   leaving 84 bytes for local variables. Maximum is 2048 bytes.
   ==> F10209  - 2134 digit number
   F0 .. F10209 matches the python fibonacci program below
    a = 0
    b = 1
    for cnt in range(10250):
        print cnt, a
    (a,b) = (b, a+b)
    cnt = cnt + 1
   Could minimize the Serial buffers ...
#define NR 712
#define ARSIZE (NR*10/8)
uint8_t a[ARSIZE];
uint8_t b[ARSIZE];
  Serial.write('\n');
  memset(a, ARSIZE, 0);
  memset(b, ARSIZE, 0);
  set(b, 0, 1);
  for (int x = 0; x <= 1000; x++)
    if (x < 1000 || x % 1000 == 0 || x >= 10200)  // remove this to see them all
      Serial.print(x);
      Serial.write(' ');
      bool skipMostLeadingZeros = true;
      for (int16_t i = NR - 1; i >= 0; i--)
        uint16_t t = get(a, i);
        if (t == 0 && skipMostLeadingZeros) continue;
        skipMostLeadingZeros = false;
        if (t < 100) Serial.write('0');
        if (t < 10) Serial.write('0');
        Serial.print(t);
      Serial.write('\n');
    add();
// packs 4x3 digits in 5 bytes
uint16_t get(uint8_t *p, int idx)
  uint16_t val = 0;
  int b1 = (idx * 10) / 8;
  int b2 = b1 + 1;
  switch (idx % 4)
    case 0:
      val = p[b1];
      val <<= 2;
      val |= (p[b2] >> 6);
    case 1:
      val = p[b1] & 0x3F;
      val <<= 4;
      val |= (p[b2] >> 4);
    case 2:
      val = p[b1] & 0x0F ;
      val <<= 6;
      val |= (p[b2] >> 2);
    case 3:
      val = p[b1] & 0x03;
      val <<= 8;
      val |= (p[b2]);
  return val;
void set(uint8_t *p, int idx, uint16_t val)
  int b2 = b1 + 1;
  switch (idx % 4)
    case 0:
      p[b1] = val >> 2;
      p[b2] = (p[b2] & 0x3F) | (uint8_t)(val << 6);
    case 1:
      p[b1] = (p[b1] & 0xC0) | (uint8_t)(val >> 4);
      p[b2] = (p[b2] & 0x0F) | (uint8_t)(val << 4);
    case 2:
      p[b1] = (p[b1] & 0xF0) | (uint8_t)(val >> 6);
      p[b2] = (p[b2] & 0x03) | (uint8_t)(val << 2);
    case 3:
      p[b1] = (p[b1] & 0xFC) | (uint8_t)(val >> 8);
      p[b2] = val & 0xFF;
// add numbers in groups of 3 digits
void add()
  // the grps indicates which elements of the array actually
  // are > 0 so need to be added
  // leading zeros do not need to be added.
  static uint16_t grps = 2;
  // overflow is tricky as compensating afterwards in a loop
  // is not possible
  uint8_t carry = 0;
  for (uint16_t i = 0; i < grps; i++)
    uint16_t ta = get(a, i);
    uint16_t tb = get(b, i);
    uint16_t tc = ta + tb + carry;
    set(a, i, tb);
    if (tc < 1000)
      set(b, i, tc);
      carry = 0;
      tc -= 1000;
      set(b, i, tc);
      carry = 1;  // add carry for next iteration
  if (get(b, grps - 1) > 0) grps++;
// END OF FILE
updated add()
