Hello Folks,
I am new to programming and I want to know how available() fuction works. My file is called TEST and it is in CSV format. I have three numbers that are seprated by commas and are as following: 11,222,333.
When I use the following code
#include <SD.h>
int CS_pin=4;
char reading[]="";
char *pstring= reading;
int availablebytes=0;
{Serial.begin(9600);
if(!SD.begin(CS_pin))
{Serial.println("SD card failed to connect");
return;
Serial.println("we are good to go");
void loop ()
File TEST =SD.open("TEST.csv",FILE_READ);
if(TEST)
availablebytes= TEST.available();
Serial.print(availablebytes);
I get the following:
we are good to go
9303930393039303930393039303930393039303..
what does 9303 stand for and how is this working?
Thank You for your help ![]()
