Fill an array with string from SPIFFS file
Hi guys! I've got a file.txt in my SPIFFS where I store 5 row of json object in this format
{"AcX": 1625, "AcY": -225, "AcZ": 1235, "time": 3000}
{"AcX": 1625, "AcY": -25, "AcZ": 1556, "time": 6000}
{"AcX": 1625, "AcY": -132, "AcZ": 1789, "time": 9000}
{"AcX": 1625, "AcY": -67, "AcZ": 345, "time": 12000}
After I filled my file.txt with my 5 rows I call a function that read the file, store every row in the array and then I send it via mqtt to my topic.
void mqtt_publish(){
  //Open and read the file
  File file = LittleFS.open("/file.txt", "r");
  if(!file){
    Serial.println("file open failed");
  } //Serial.println("------ Reading ------");
  //Create an empty array
  JsonArray arr = doc.to<JsonArray>();
  for (int i=0; i<=5; i++){
    String s = file.readStringUntil('\n');
    JsonObject obj = doc.createNestedObject();
    doc[i].add(serialized(s));
  char sendread[MQTT_BUFFER];
  serializeJsonPretty(doc, sendread);
  int ret = client.publish("esp8266/JSON", sendread);
  file.close();
Anyway the output in the serial monitor is this
12:47:54.208 -> Message arrived in topic: esp8266/JSON
12:47:54.208 -> Message:[
12:47:54.208 ->   {},
12:47:54.208 ->   {},
12:47:54.208 ->   {},
12:47:54.208 ->   {},
12:47:54.208 ->   {},
12:47:54.208 ->   {}
12:47:54.208 -> ]
The array with the 5 elements it's created but not filled. What am I missing? Thanks a lot!
You have to show the code where you prepare the JSON object for printing to the serial console.
That's the callback
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived in topic: ");
  Serial.println(topic);
  Serial.print("Message:");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println("-----------------------");
what's doc?  JsonArray arr = doc.to<JsonArray>();what's the purpose of arr?
Don't post snippets please (Snippets R Us!)
Not best practice to print from the callback but...shrug.
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', 150 );
  x_message.topic = ""; //clear string buffer
  x_message.topic = topic;
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  //log_i( "topic %s payload %s" ,x_message.topic, x_message.payload );
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
I uncomment the //log_i( "topic %s payload %s" ,x_message.topic, x_message.payload ); line to print. Remember printing is a time consuming effort by the MCU.
Spoted the thing your missing in your payload parsing?
I noticed you do the thing a bit differently.
I create the message structure here:
struct stu_message
  char payload [150] = {'\0'};
  String topic;
} x_message;
In setup I limit the string size to make a buffer and prevent string memory fragmentations.
x_message.topic.reserve(150);
Yep I know @Idahowalker, infact I only need to send the array via mqtt, and in my function I wrote
I was printing on the serial monitor just to check the result
Idahowalker:
 // clear locations
 int i = 0;
 xQueueOverwrite( xQ_Message, (void ) &x_message );// send data
Wow, that's a lot. I'm a newbie to arduino an C programming. It's quite different the syntax I'm not sure what I'm looking at. There's nothing easier for me to solve my problem? I still don't get what am I missing
What I understand is that the message has been sent but when the receiver callback gets triggered a receipt of data is not indicated.
Find, download, and install MQTT.fx. Connect to your broker and see what is being published by going to the subscribe thingy, scan for posted topics. See the topic in the scan, click on it to see the payload. Id it empty, sending issue. If their is data then receiving issue.
Prove sender or receiver as being as fault.
Idahowalker:
Find, download, and install MQTT.fx. Connect to your broker and see what is being published by going to the subscribe thingy, scan for posted topics. See the topic in the scan, click on it to see the payload. It it empty, sending issue. If their is data then receiving issue.
Ok that's the problem, even in the topic the message is empty. So the problem it's in the sending function, but I can't see what's causing it
[color=#b72828][
][/color]
You create arr and obj but never use them, I think you should look at the ArduinoJson documentation
guix:
JsonArray | ArduinoJson 6
JsonArray::createNestedObject() | ArduinoJson 6
StaticJsonDocument<200> doc;
JsonArray array = doc.to();
JsonObject nested = array.createNestedObject();
nested["hello"] = "world";
serializeJson(array, Serial);
With the difference I was trying to fill the array through a for loop
That's how I declared the capacity and the array
//compute the required size
const size_t CAPACITY = JSON_ARRAY_SIZE(5) + 5*JSON_OBJECT_SIZE(4);
//allocate the memory for the document
StaticJsonDocument<CAPACITY> doc;
as asked in #3, you don't use the array - so you are not filling it through a for loop...where do you see arr in
J-M-L:
Ok I understand, but how do I fill the array? I'm getting confused by all the nested staff
if you really need to have separate lines, each being a little JSON object, then I would just have a global doc that will be the end result and add in each line.
==> read a line, build a temporary JSON by de-serializing that line, and add it to the global doc.
Once you've finish reading the file then the global doc holds a JSON array with all your lines.
something like this. Typed here, not tested... give it a try
#include <SPIFFS.h>
#include <ArduinoJson.h>
DynamicJsonDocument globalDoc(1000);
  if (!SPIFFS.begin()) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    while (true) yield();
  File file = SPIFFS.open("/file.txt", "r");
  if (!file) {
    Serial.println("Failed to open test file");
    String jsonLine;
    jsonLine.reserve(100);
    StaticJsonDocument<100> localDoc;
    while (file.available()) {
      jsonLine = file.readStringUntil('\n');
      DeserializationError error = deserializeJson(localDoc, jsonLine);
      if (!error) globalDoc.add(localDoc);
    serializeJsonPretty(globalDoc, Serial);
    file.close();
void loop() {}
if all works OK, Serial Monitor (@ 115200 bauds) will show something like this (give or take, you might have each entry on a separate line)
[color=purple]
[b][color=red][[/color][/b]
  {"AcX": 1625, "AcY": -225, "AcZ": 1235, "time": 3000}[b][color=red],[/color][/b]
  {"AcX": 1625, "AcY": -25, "AcZ": 1556, "time": 6000}[b][color=red],[/color][/b]
  {"AcX": 1625, "AcY": -132, "AcZ": 1789, "time": 9000}[b][color=red],[/color][/b]
  {"AcX": 1625, "AcY": -67, "AcZ": 345, "time": 12000}[b][color=red],[/color][/b]
[b][color=red]][/color][/b]
[/color]
if you are in charge of the format of the SPIFF file, then why don't you make it a true JSON array in the first place and make it look like the above. This way you could just create your JSON donc in one godeserializeJson(doc, file);
PS: of course the size of the global and local JSON docs need to be adapted to the requirements.
J-M-L:
#include <SPIFFS.h>
 if (!file) {
   String jsonLine;
   file.close();
void loop() {}
 {"AcX": 1625, "AcY": -225, "AcZ": 1235, "time": 3000},
 {"AcX": 1625, "AcY": -25, "AcZ": 1556, "time": 6000},
 {"AcX": 1625, "AcY": -132, "AcZ": 1789, "time": 9000},
 {"AcX": 1625, "AcY": -67, "AcZ": 345, "time": 12000},
Ok it seems to work, not fully but I hope I'll manage to solve other issues.
Just one last question! I am in charge of the format of the SPIFFS, but this is the first time with SPIFFS and also arduino programming so I didn't know how to manage all these things. So how could I create my doc as a JSON doc in one go?
edward_radical:
Not sure I understand the question.
JSON is a documented format.
JSON defines only two data structures: objects and arrays.
An object is a set of name-value pairs, and an array is a list of values (amongst seven value types: string, number, object, array, true, false, and null)
So decide how you wan to represent the JSON data
For example this would be one array (using []) holding multiple objects (using {}), each object having 4 properties (name-value pairs): AcX, AcY, AcZ and time
You could make it more compact as the labels are useless (you can access through indexes)
  [1625, -225, 1235, 3000],
  [1625, -25, 1556, 6000],
  [1625, -132, 1789, 9000],
  [1625, -67, 345, 12000],
so this would be an array of array holding numbers
J-M-L:
I was referring at this
well if the file is a JSON format already then it's really just that line... So the original code would become
#include <SPIFFS.h>
    Serial.println(F("An Error has occurred while mounting SPIFFS"));
  if (!file) {
    Serial.println(F("Failed to open test file"));
    DeserializationError error deserializeJson(globalDoc, file); // <=== READ THE FILE AS A JSON
    file.close();
    if (!error) serializeJsonPretty(globalDoc, Serial);
    else Serial.println(F("Failed to read JSON"));
void loop() {}
J-M-L:
#include <SPIFFS.h>
 if (!file) {
   String jsonLine;
   file.close();
void loop() {}
Everything works this way, I have just one last question. What should I do if I want to send the content of globalDoc to my topic via mqtt? I tried this but doesn't work:
  if(!file){
  }else {
    String jsonLine;
    StaticJsonDocument <100> localDoc;
    serializeJsonPretty(globalDoc, sendread);
    file.close();
I added the last 4 lines after what you suggested
please don't quote full messages. This is totally useless and makes reading the thread cumbersome. My text is already readable above
To your question, have you looked at the extensive documentation of the Arduino JSON library? try this
char buffer[1024]; // adjust to what's needed (should be the file size)
size_t n = serializeJson(globalDoc, buffer);
client.publish("esp8266/JSON", buffer, n);
but if this is the only thing you do with globalDoc, as your file is already in JSON format now, there is no need to deserialize and serialize... just read the file into the char buffer and publish it. You'll save all the memory needed by JSON stuff
