Hello,
I'm using an Arduino in a mobile project that goes to sleep all the time to save power - it only needs to be up and running while the device is moving. To do this, I have a tilt-switch-esque sensor which essentially open and short circuits itself on vibration. It is normally closed, but opens and closes on vibration / rotation. In order to properly use the sensor, it needs a filter on it to both save power and not be overly sensitive.
You can see the datasheet for the sensor here: SQ-SEN-200%20Omnidirectional%20Tilt%20and%20Vibration%20Sensor%20Datasheet.pdf - Google Drive
I've got a filter circuit that uses this device to hold the signal low until movement, at which point the TO_MCU line (see schematic) goes high. Unfortunately, to wake up, the ATMega's need a LOW level interrupt, not a high one like this circuit provides.
The schematic for the filter circuit is here:
So my ultimate question is: how would I go about modifying this circuit so that it works in the opposite direction (ie - regularly high on TO_MCU, but goes low on movement)? I'm pretty much a complete electronics noob, so I don't even know where to start.
Thanks for any help at all you can provide!
