Find in Messages problem
I am involved in a long exchange of messages with a user and need to find when I first suggested the use of a command in the sketch that we are developing
The command that I wish to find is RUN: but I can't make the search work. Searching for RUN allows the usual this topic/all topics and posts option but is of little use in the context of the conversation
Using RUN: as a search term produces this odd dialogue box
Searching for "RUN:" does not offer the choice of "this topic"
The problem seems to be the word RUN and/or the colon
Has anyone got any ideas as to how I can search for RUN:
It looks like the engine used the colon as a way to filter, it might get confused without the double quotes
Did you try
"RUN:" @UKHeliBob
Or
"RUN:" @UKHeliBob topic:501127
Where 501127 is the topic Of interest’s ID
➜ may be this thread? Up counter using millis() and Arduino Uno - #39 by UKHeliBob
That works. Thanks for the suggestion
In the meantime I found another term to search for that worked. Thank goodness for version numbers of sketches and notes as to what was added in each
Definitely a good practice that we don’t see enough
Thanks! That nicely explained I was having the same issue by the way.
