Hello,
I have a doubt.
Is it possible to add a label in the text file which is stored in SD card and read from this label when want from the program.
Hello,
I have a doubt.
parnal:
Hello,I have a doubt.
What do you mean by "add a label"? A label is just a piece of text. Adding text to a text file is easy.
What do you mean by "read from this label"? You read from a file, not from a piece of text.
Suppose, I have a program to find a String in the Text file.
When this String is found in the text file in SD Card, I want to read the content of this text file from this found String.
The program to find the string in the text file on SD Card:
#include <SD.h>
File myFile;
char buf[20];
while (!Serial) {
; // wait for serial port to connect
Serial.print("Initializing SD card...");
pinMode(SDCARD_SS_PIN, OUTPUT);
if (!SD.begin(SDCARD_SS_PIN)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// re-open the file for reading:
myFile = SD.open("test1.txt");
if (myFile) {
Serial.println("test1.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
myFile.read(buf,7);
if(strncmp(buf, "Readfromhere", 12) == 0)
Serial.println("Match!");
//should read the content of files after this String
// close the file:
myFile.close();
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// nothing happens after setup
The content of the text file looks like this :
HELLO
I am reading the file
Readfromhere
Line1
Line2
The result printed on the serial monitor after string found should be :
Line1
Line2
myFile.read(buf,7);
That would work great if your file is organised in blocks of 7 bytes. But what happens when you try to read this example file?
xReadfromhere
You get xReadfr, omehere.
Also, why are you trying to compare 12 characters in the buffer that was only filled with 7?
Hey Morgan,
was working on the other example with different text written in the file.
Obviously I will increase the buf size.
Hello,
The file finds the string written on the first line of the text file, but refuses to find the string written on the next line . How does this work?
#include <SD.h>
File myFile;
char buf[20];
while (!Serial) {
return;
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
myFile.read(buf,6);
if(strncmp(buf, "here", 4) == 0)
// close the file:
myFile.close();
text file content:
Hello
here
read
write
The same program works fine if the string to be found is Hello but for here, read and write it doesnt work
parnal:
Hello,The file finds the string written on the first line of the text file, but refuses to find the string written on the next line . How does this work?
#include <SD.h>
File myFile;
char buf[20];
while (!Serial) {
return;
if (myFile) {
myFile.read(buf,6);
// close the file:
myFile.close();
text file content:Hello
here
read
writeThe same program works fine if the string to be found is Hello but for here, read and write it doesnt work
the content of buf after the first read is: H e l l o \n
the content of buf after the second read is: h e r e \n r
the content of buf after the third read is: e a d \n w r
this assume that \n denotes the linefeed, the content of buf is different if the line is terminated by \r\n
Hello,
How can this be fixed?
As I can see the string size when fixed to same length its easier to find it. But definitely this is not my case.
I've got a tennis racket, a baseball bat, and a golf club. I'm going to hit you several times with the tennis racket, then once with the baseball bat and once with the golf club.
Can you tell which is which, when I hit you?
Well, you should be able to tell, when you read a character from the file, if it is a carriage return (baseball bat), a line feed (a golf club), or something else (useful, the tennis racket), and take the appropriate action - store the data, toss the data, or reset for processing the next record.
parnal:
Hello,
Read blocks of 1, not 6.
Then look for the individual characters. Look for the 'h' first. If you found an 'h' you expect to see 'e'. If you don't find the 'e' go back to looking for the 'h'.
Hello all,
Thank you, It helped a lot to understand the problem.
