Finding a FQBN for a device that doesn't come up on board list
My board is a non genuine arduino NANO.
It does't come up on arduino-cli board list
I have learnt that this is because of:
pert
"This is expected and normal for any board that uses a general purpose USB to serial adapter chip (e.g., FTDI FT232, CH340). The reason is that these chips use a VID/PID provided by the manufacturer, rather than a custom, board-specific ID as is done on the more modern official Arduino boards. This means there is no way to know which board that generic VID/PID is associated with. You'll notice that the Arduino IDE's Tools > Board menu and Tools > Board Info are also unable to identify these boards. This is not a situation where Arduino intentionally didn't provide support for clones and 3rd party compatible boards. The same applies even to the official Arduino Nano (and Diecimila as well, I believe), which uses the FTDI FT232 with its manufacturer-provided VID/PID. There is simply no possible way for these boards to be identified.
It doesn't mean you can't use the boards. It only means that the convenience features like arduino-cli board attach and arduino-cli board list don't work quite as well with these boards. The essential features will still work perfectly well."
My question: Is there any way to find out the boards FQBN? So that I can compile my code with
arduino-cli compile -b arduino:avr:uno /home/user/Arduino/MySketch
Hi @Harley4DaWin
As you already discovered, there is no way for the FQBN to be automatically discovered. However, you can simply look up the FQBN of the Nano. You can get a listing of all installed boards with this command:
arduino-cli board listall
That may give you a lot of boards, so you can filter it with grep if you like:
arduino-cli board listall | grep --ignore-case "nano"
You will now have learned that the FQBN of the Nano is arduino:avr:nano. You will usually just be able to use the FQBN as is. However, some boards have custom board options that allow additional configuration. These custom board options are also set via the FQBN. You can learn about the custom board options of the Nano with this command;
arduino-cli board details arduino:avr:nano
which gives this output:
Board name:             Arduino Nano
FQBN:                   arduino:avr:nano
Board version:          1.8.3
Official Arduino board: ✔
Package name:           arduino
Package maintainer:     Arduino
Package URL:            https://downloads.arduino.cc/packages/package_index.json
Package website:        http://www.arduino.cc/
Package online help:    http://www.arduino.cc/en/Reference/HomePage
Platform name:          Arduino AVR Boards
Platform category:      Arduino
Platform architecture:  avr
Platform URL:           http://downloads.arduino.cc/cores/avr-1.8.3.tar.bz2
Platform file name:     avr-1.8.3.tar.bz2
Platform size (bytes):  4941548
Platform checksum:      SHA-256:de8a9b982477762d3d3e52fc2b682cdd8ff194dc3f1d46f4debdea6a01b33c14
Required tool:          arduino:avr-gcc        7.3.0-atmel3.6.1-arduino7
Required tool:          arduino:avrdude        6.3.0-arduino17
Required tool:          arduino:arduinoOTA        1.3.0
Option:                 Processor        cpu
                        ATmega328P                                                   ✔                              cpu=atmega328
                        ATmega328P (Old Bootloader)        cpu=atmega328old
                        ATmega168        cpu=atmega168
Programmers:            Id                                                           Name
                        arduinoisp                                                   ArduinoISP
                        stk500                                                       Atmel STK500 development board
                        parallel                                                     Parallel Programmer
                        jtag3isp                                                     Atmel JTAGICE3 (ISP mode)
                        arduinoasisp                                                 Arduino as ISP
                        usbtinyisp                                                   USBtinyISP
                        atmel_ice                                                    Atmel-ICE (AVR)
                        avrisp                                                       AVR ISP
                        arduinoisporg                                                ArduinoISP.org
                        usbGemma                                                     Arduino Gemma
                        buspirate                                                    BusPirate as ISP
                        jtag3                                                        Atmel JTAGICE3 (JTAG mode)
                        avrispmkii                                                   AVRISP mkII
                        usbasp                                                       USBasp
                        arduinoasispatmega32u4                                       Arduino as ISP (ATmega32U4)
Perhaps a little more information than you needed, but arduino-cli is a tool for advanced users so we need to provide for all use cases.
For your case, the important information is under the "Option" section:
You can see that there is one option. The human friendly name for this option, which you would see under the Arduino IDE's Tools menu when the board was selected, is "Processor". However, the FQBN is the way we identify the board to a machine, and this uses the option ID: cpu.
The cpu option has three possible settings:
  • atmega328
  • atmega328old
  • atmega168
You can see that the default value of this option is "atmega328". In the Arduino IDE, you would set this via the Tools > Processor > ATmega328P menu option. This is the appropriate option to use for official Arduino Nanos purchased in 2018 onward. You don't need to specify the default option via the FQBN, so if you have a modern officail Arduino Nano, you can simply use the FQBN arduino:avr:nano.
Before 2018, Arduino used a different bootloader on their Nano boards. If you have one of these boards with the old bootloader, you need to use the atmega328old option. The option id and value is appended to the base FQBN. So the FQBN to use for the Nano with the old bootloader is arduino:avr:nano:cpu=atmega328old
Clone and derivative Nano boards often have the old bootloader, but some have the new bootloader, and of course the sellers would never bother to tell you which it is. So if you have one of these boards, you'll just need to use trial and error to determine which of the options is appropriate for your board.
Some boards have multiple custom board options. To specify multiple options via the FQBN, just separate them with commas. For example:
esp8266:esp8266:generic:xtal=160,baud=57600
It doesn't matter which order the options are in.
In the case of boards with a lot of options, I will often just configure the board as I like in the Arduino IDE and then do a compilation of any sketch with verbose output during compilation enabled in File > Preferences, then just copy/paste the FQBN from the first line of the compilation output.
