Finding functions...
Greetings everyone...
I'm currently looking at a code example for MPU-6050 usage, written by Jeff Rowberg.
In this code there are statements that use a function called 'F' with a double quoted string as a parameter.
My first question is, in a case like this where I want to know what 'F(string)' does, how do I locate where the function comes from. I mean is there an IDE based way to easily find the function/method or its declaration? Or am I forced to try to search all the includes until I find it. I've looked at the Arduino IDE reference page and cannot find anything; and I seriously doubt there would be an official function named 'F'...
The only includes in the code example are:
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
and here are a couple of lines using the function:
  // verify connection
  Serial.println(F("Testing device connections..."));
  Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
What general procedure would one of you experienced folks follow to track down what 'F' is?
I'd read the manual
(F is a macro, not a function)
@OP
This is the link for the above quote.
GolamMostafa:
Awesome! Thank you!
Follow on question: Where can I read more to help me understand why I might want to use the flash memory versus SRAM?
If you're using constant literal strings, use flash, otherwise use RAM.
first link in the article about PROGMEM: Arduino Playground - Memory
Some things for you to master:
Arduino links of interest.
How to use this forum:
https://forum.arduino.cc/index.php?topic=149014.0
Listing of downloadable 'Arduino PDFs' :
Either Google >>>- - - - > arduino filetype: pdf
Or
https://www.google.ca/search?q=arduino+filetype%3A+pdf&rlz=1C9BKJA_enCA739CA739&oq=arduino+filetype%3A+pdf&aqs=chrome..69i57j69i65.1385j0j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8
Listing of downloadable 'C++ PDFs' :
Either Google >>>- - - - > C++ filetype: pdf
Or
https://www.google.ca/search?q=c%2B%2B+filetype%3A+pdf&rlz=1C9BKJA_enCA739CA739&oq=c%2B%2B+filetype%3A+pdf&aqs=chrome..69i57.22790j0j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8
Arduino cheat sheet:
Troubleshooting common errors:
Watch these:
Arduino programming syntax:
Arduino arithmetic operators:
Arduino control flow:
Arduino data types:
Some things to read
https://learn.adafruit.com/category/learn-arduino
https://learn.sparkfun.com/tutorials/how-to-read-a-schematic
Language Reference:
Foundations:
How and Why to avoid delay():
http://playground.arduino.cc/Code/AvoidDelay
Demonstration code for several things at the same time.
http://forum.arduino.cc/index.php?topic=223286.0
Useful links:
https://forum.arduino.cc/index.php?topic=384198.0
Arduino programming traps, tips and style guide:
Jeremy Blume:
Arduino products:
Motors/MOSFETs
Switches:
Share tips you have come across, 500+ posts:
https://forum.arduino.cc/index.php?topic=445951.0
Images from above:
https://www.google.com/search?q=“Share+tips+you+have”+larryD+site:https://forum.arduino.cc&prmd=nmvi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiJw-zu68ncAhXPGTQIHWCDCNwQ_AUIFCgE&biw=1024&bih=653
Debug discussion:
https://forum.arduino.cc/index.php?topic=215334.msg1575801#msg1575801
